magic calipers
(In Topic #102770)
![wooders in the usergroup ‘Local hero’ wooders in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
magic calipers
![](https://vwgolfmk1.org.uk/uploads/pbextract/861435/carbits048.jpg)
and hey presto, now they will
![](https://vwgolfmk1.org.uk/uploads/pbextract/861435/carbits047.jpg)
![Avatar](https://i222.photobucket.com/albums/dd103/iPod_Fixer/000177.png)
![X in the usergroup ‘Local hero’ X in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
am i missing something, all that seems to be different is the ridiculous blur on the bottom half of the shot… or is this another 'woodersism'?
1983 Golf 1.3 Driver:
![](https://i222.photobucket.com/albums/dd103/iPod_Fixer/182000_zpsdfa6a837.png)
![Avatar](https://i245.photobucket.com/albums/gg80/novocaine10/n731220548_174194_274-1.jpg)
![novocaine in the usergroup ‘Local hero’ novocaine in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/half-life.jpg)
![Lawsy in the usergroup ‘Local hero’ Lawsy in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://i116.photobucket.com/albums/o17/the_parrs/Honeymoon/PICT0071.jpg)
![ant5 in the usergroup ‘Paid Member’ ant5 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![ant5 in the usergroup ‘Regional Hosts’ ant5 in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![ant5 in the usergroup ‘Local hero’ ant5 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
1979 mk1 Golf Gti (Dan)
2010 T5 Karmann Colorado
2012 mk6 Golf Tdi convertible
2019 Skoda Octavia Sport ( it’s Golf)
![welsh-mk1 in the usergroup ‘Local hero’ welsh-mk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
ant5 said
He has put bolts in the Holes….. Or he is taking photo`s with one handops:
Magic bolts.
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/forks.png)
![djheap22 in the usergroup ‘Old timer’ djheap22 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
1988 1.8 carb Golf Clipper
yep. got special shaped spacers and longer bolts to fit the to mk1 carriers using rover 216 gti discs. need to t piece the brake lines and on they can go.djheap22 said
fitted longer bolt with shims to get the caliper in the right position when bolted to the carrier. :dontknow:
![thoyland in the usergroup ‘Local’ thoyland in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![mcscrew in the usergroup ‘Local hero’ mcscrew in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Also, do those calipers bolt to standard GTI carriers?
Rich
![chrismk1jetta in the usergroup ‘Local’ chrismk1jetta in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
they calculated this in the mag (c&cc) when they did the conversion and it was considered fine. i can't find the article at the moment but if i do, i'll post it up.paul_c said
I don't suppose anyone knows the total surface area of the twin cylinders in the Volvo calipers as a comparison of the stock VW one. This info would be needed to calculate the resulting diameter of master cylinder needed, and/or the change in pedal stroke due to the changes.
![racer in the usergroup ‘Local’ racer in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![frackagx60 in the usergroup ‘Regular’ frackagx60 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![collo16v in the usergroup ‘Old timer’ collo16v in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
