magic calipers
(In Topic #102770)
magic calipers
and hey presto, now they will
am i missing something, all that seems to be different is the ridiculous blur on the bottom half of the shot… or is this another 'woodersism'?
1983 Golf 1.3 Driver:
1979 mk1 Golf Gti (Dan)
2010 T5 Karmann Colorado
2012 mk6 Golf Tdi convertible
2018 VW Amarok V6
2018 VW Amarok V6
ant5 said
He has put bolts in the Holes….. Or he is taking photo`s with one hand ops:
Magic bolts.
1988 1.8 carb Golf Clipper
yep. got special shaped spacers and longer bolts to fit the to mk1 carriers using rover 216 gti discs. need to t piece the brake lines and on they can go.djheap22 said
fitted longer bolt with shims to get the caliper in the right position when bolted to the carrier. :dontknow:
Also, do those calipers bolt to standard GTI carriers?
Rich
they calculated this in the mag (c&cc) when they did the conversion and it was considered fine. i can't find the article at the moment but if i do, i'll post it up.paul_c said
I don't suppose anyone knows the total surface area of the twin cylinders in the Volvo calipers as a comparison of the stock VW one. This info would be needed to calculate the resulting diameter of master cylinder needed, and/or the change in pedal stroke due to the changes.
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
