mk1 golf/ tt conversion project.
what should go ? |
woman ? |
or car ? |
This poll is closed. You cannot vote unless it is reopened. | |
(In Topic #100533)
Member 125 - 2005
mk1 golf gti in alpine white, very good condition, used to run a g60 lump and so all brakes and suspension has been uprated, loads of spec / history will list when i get time. audi tt bam engine fitted, new g60 steels & tyres , never been used on the road q-peng wiring loom and down pipe, emerald md3, forge splitter dv, K04 turbo. the car is about 90% complete. to finish it needs starter motor, turbo water pipes fitting, wiring loom connecting up and rolling road set up. a lsd would be a good idea but at about ?600 that's your choice. i have a map for it which i was told is set at 210bhp, but can be changed to 280 bhp if you'd ever need it. i know if i finished it i would get a lot more for it, but time & money is against me, i might consider a px with a standard mk1 gti but i will not break it , i want to see it finished. call me on 07956432102 for more details. ?3895 ovno.
![](https://vwgolfmk1.org.uk/uploads/pbextract/842053/mk1007.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/842053/ebaysale093.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/842053/ebaysale117.jpg)
Member 125 - 2005
Member 125 - 2005
if you were not so far away id help out but alas to far sorry :cry:
Member 125 - 2005
do you have a map in the ecu thats good to go?
if its just a case of wiring up and fitting a few pipes then your not looking at much maybe about 2 days work tops
my problem at the moment is a lack of time if your thinking 3 or 4 weeks down the line then i maybe able to help failing that paul_c is closer to you than me i think
where you located
Member 125 - 2005
you said you have a qpeng loom?? whys that
Member 125 - 2005
as for the turbo pipes im guessing you have them
Member 125 - 2005
