Ebay coil Overs - ?200 Hot Tuning
(In Topic #99319)
![tazzy01 in the usergroup ‘Newbie’ tazzy01 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
After seeing a few people having said these kits were ok I decided to buy a set.
http://cgi.ebay.co.uk/COILOVER-VW-GOLF-MK1-MK2-MK3-MK4-SPECIAL-OFFER_W0QQitemZ170227656604QQihZ007QQcategoryZ40192QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
I fitted the rear at the weekend and although I understand the ride will change the ride can only be comparable to driving on wooden wheels or bricks. Its taken 3 days to rattle the rear exhaust box rubbers off.
whe I originally fitted them the car was so low I couldn't get the jack from out underneath the sills. Once it was wound up a bit the hight is better but the ride is still awful.
I'm thinking I may have had the wrong kit delivered or something? I've wound the smaller bottom spring so much that its no longer a spring. I'll upload some photos at the weekend but does anyone have any idea why the ride would be so bad?
i was thinking of giving in and getting some better shocks, I've seen the venom Venom Motorsport Performance Car Parts - EBC Brakes, Black Diamond Brakes, FK Suspension, Eibach Suspension, Weitec Suspension, Supersport Suspension anyone have any thing to say about these?
or these?
http://www.europerformance.co.uk/pages/products/category_results.mhtml?category=fkhighsportcoiloverkits&car=vwgolf1&manufacturer=fksuspension&sub_category=1
thanks for your help!
P
![Avatar](https://i245.photobucket.com/albums/gg80/novocaine10/n731220548_174194_274-1.jpg)
![novocaine in the usergroup ‘Local hero’ novocaine in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
have you fitted the fronts yet?
![thedaddy in the usergroup ‘Local’ thedaddy in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
For the price I have paid I am pleased with the result-I lowered my MK1 back in 1989 and these feel tighter than the kit I had the first time round.
Suggest you return to stock parts if the ride is too harsh, this will be the only way to get factory ride quality.
![ThE_gOg in the usergroup ‘Old timer’ ThE_gOg in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Chris
Need your console repaired or mods done? drop me a pm
![:)](http://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/smile.png)
Nova: I've not put the front on yet, after the poor performance on the rear I wasn't going to spend the time doing the front. I'll get some new top mounts (the rubber cones yeah?) and stick the fronts on, it might be a little better but I think I've been givin polo shocks or something
chris would you recomend the FK ones or any other ones??
the weitecs ride is just right for me and they are very well made. they're made by kw which make high end coilovers, under the weitec name.
i've never had fk's but have heard mixed things about them.
hth
Chris
![Robmk1 in the usergroup ‘Local’ Robmk1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
tazzy01 said
thanks for the replys
Using worn 'normal' suspension one end and new coilovers on the other will not do anything for your handling and ride quality at all 8O
Fit the fronts as well and get everything set up e.g tracking and camber before you decide you don't like them.
I'm using these and don't find them a problem at all. Superb road holding if a little on the hard side
after fitting the rear I didn't want to waste my time fitting the front, then spend money on the camber and tracking only to be taking it all off a week later.
I'll stick the front on and see how it is. I really can impress how hard the ride is though, for instance if I push the boot down there is no play, nothing at all.
![funk-star in the usergroup ‘Local hero’ funk-star in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Fair enough, but to be fair, even if you go for the better ones the ride will be hard. Thats coilovers for ya!
I don't think coilovers are for you chap!!!!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/S7302922BW.jpg)
![Kenno in the usergroup ‘Old timer’ Kenno in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![maccagti in the usergroup ‘Local’ maccagti in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
i fanally got mine set up perfectly today and i cannot tell you how much of an improvement its made to the handling
maccagti said
maybe -40mm over standard ride height but its very hard with them wound right up!!!
Robmk1 said
tends to be the other way round.
So which one is it then, can anyone confirm, i thought it was if wound all way down they have a shorter distance for the spring to take road impacts etc. I could be wrong
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fimg1.jurko.net%2Favatar_3427.gif)
![welchy in the usergroup ‘Local’ welchy in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
