2.0l 16v charged - track action vid 7/9/09
PhillTMK1GTI said
tempted to find a back box that's shorter?
excuse you!!! 8O
I looked better when the bumpers were on, but I dont think its too bad, helps keep the crud away from the car,
good point about keeping the crud away :wink:
M7R said
aye Im hoping to be on track after I finish uni as a way to let off some steam so not too long!
also on the plus side - I HAVE BRAKES!!!!!!!!!!!!!!!!! 8O :twisted: my bargin master cylinder from the scrappy off a audi 80 has finally given in to me!!! i had to get a eazybleed thing that conects to the tyre and run it a little higher than the 20psi it says :twisted: but all the brakes have now bleed, and all 4 outlets give fluid so ive plumbed in the brke light switch to one of the spare ones.
the only issue now is that the adaptor brakes are STILL catching my discs!!! :evil: so they need another touch with the grinder, but while they are dragging they are making a groove on the surface (luckly at the very inside edge of the disc) and making pushing the car in and out on my own impossible! but hey ho, suh is life.
Are you running the audi 80 master cylinder off the standard servo? If so did the master fit in correctly? Hows the pedal response, harder than usual or about the same, less travel, sharper biting etc… Are you using the original brake lines? Have you got a pic of the setup? Sorry for all the q's but im thinking of doing the same but still using the standard servo, as mk2 gti 16v servo and master combos are going ridiculous prices these days. Loving your car by the way, the debumpered look looks awesome, and your ride height is just right with the way those wheels sit in the arches, but to be honest i prefered the ronals. Otherwise looks awesome, get some pics of the bay posted.
Cheers.
Im yet to drive the car as I havent been able to due to the wheels, fingers crossed Ill get down the road next week if the weathers good. but the first signs are good, the pedal feed nice and firm and seems pretty good.
Im still on rubber hoses at the mo, I have 2 braded ones for the front to go on next week - the rears are being left as this way it will help stop them lockng under hard braking.
on the servo front a 3:1 servo from a mk2 etc will not give better brakes all it does it mean you ahve to apply less pressure. the same effect can be had with the origial servo by pressing the pedal harder :wink: also a higher powered servo gives a more numb feel to the brake, not whats needed on track so a later servo will not be going anywhere near my car.
I will report back next week when ive driven it down the road… should be fine though 8) and ill try and get a pic of the brake lines etc.
Cheers dude.
it seemed to fit the servo fine, but im yet to drive it so it may all be poo
Will get around to posting pics and full spec at some stage.
<a href="Sigs pictures by Kitsune550 - Photobucket"><img src="http://i167.photobucket.com/albums/u157/Kitsune550/Sigs/MkI-01sig.jpg" border="0" alt="Photobucket"></a>
Let us know how it goes on yer next run.
Good luck!
BiG_J said
Nice! Although i think we both agree 10mph is not enough to justify the power of the breaking..lol, do you feel like you need more effort to brake? How would you compare it with the the standard MC?
Good luck!
i tried again the other day at 30, i think the problem is that the brakes dont need masses of effort now to brake, but they seemed a bit better the second time. i now have new rubber on so ill know tomorrow if its better or not. i dont think it helps the brakes arent bedded in yet.
And also adjusting the tranfer bar wont reduce pedal effort or travel, all its going to do is make your pedal higher or lower.
the audi MC is too big for stock vag calipers, unless you are running much larger front calipers.
the adjusting of the bar was to raise the pedal, by lengthening the bar on the bulk head the pedal is lowered, but the slack is removed from the system, then the clevis pin on the MC is removed and that link lingthened to raise the pedal back up, now the feel is very good and the travel is good too so for now im going to keep running this system. - at the same time as going back to the old MC i have also fitted braded hoses to the front which helps a little too.
Im running Vauxhall 256mm set up currently with 51mm calipers, but i have a set of 54mm calipers which i wish to use with the audi MC may even go for the larger 57mm from the later calibra turbo/v6's
As for getting rid of the slack theres another way, if you have a look at your pedal box you will notice a threaded hole inline with the brake pedal, if you can get a long enough m6 bolt and a nut to lock in position you can adjust where you want the pedal to stop.
the mc is designed to use the full play, its only a issue on old MCs where the unswept bit my have the odd bit of crub, but if its new its fine.
on the pedal adjust it wasnt the hight that was a problem. the hight of the pedal was fine, but the actual part where it started to work was low, but taking the slack out as ive said above the hight comes back to level with the clutch but there isnt the dead space where it does nothing.
If any dudes got a 16v servo for sale im interested, please pm me.
Cheers.
I also have a few pics from inters etc to put up tomorrow
Anyhow, i managed to get hold of a 9" servo from a local scrappy last week, and i can say that the audi mc fits very nicely in place, i only manged bung it all up yesterday but ive still left to change my calipers to 54mm bleed the system and some how figuire out how to mount this brake light switch i have lying around, here's a few piccy of the set up for any of those who are interested.
And a pic of the engine bay 8)
on the brake switch i used a pedal switch from a b5 pissrat etc, and have attached this to the steering column which works very well and comes on sooner than the pressure switch.
I have some more but someone hacked my photobucket and deleted them so i need to upload them again…
Taken at my dads work the day before inters
The sat meet for the dubclque stand.
Sunday pics at the end of the show when most had gone home.
the mk1s changed a bit ops:
