More work on the little black GTI...
(In Topic #98613)
Renovation
2.0 16V engine conversion
Fuelling setup
So far its best time is 14.15 secs at 94mph. (Explanatory note: as well as wearing its usual registration nuymber of TJF611X, it occasionally wears a 'special' plate Z-49-83).
![](https://vwgolfmk1.org.uk/uploads/pbextract/825559/mygolfGTItimeslip1415.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825562/Dsc04563reduced.jpg)
After a couple of hours work, I have ended up with this:
![](https://vwgolfmk1.org.uk/uploads/pbextract/825562/Dsc04767reduced.jpg)
The gearbox is now out! Here's the old and new:
![](https://vwgolfmk1.org.uk/uploads/pbextract/825562/Dsc04771reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825562/Dsc04774reduced.jpg)
(The new one is the cleaner of the two on bricks, the old one is on the tyre).
![Avatar](https://i161.photobucket.com/albums/t204/gammygolfgti/homer_simpson.jpg)
![GAMMYGOLFGTI in the usergroup ‘Paid Member’ GAMMYGOLFGTI in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![GAMMYGOLFGTI in the usergroup ‘Local hero’ GAMMYGOLFGTI in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Looks like the n/s drive flange was leaking
GAMMYGOLFGTI said
Why you changing it Paul, are the ratios better for 1/4 mile? if they are, can you tell me the ratios of a standard box's gears against a 1600 box, ta. :mrgreen:
Well, I'm crossing the finish line at approx 6300rpm (in 4th), so that means I'm not getting the most out of 4th gear. And also looking at plots from the datalogger, I can see that clearly the lower the gears, the better the acceleration achieved. So with the 1600 box (3.89 final drive) instead of an 1800 box (3.67 final drive), I can reach (almost) the rev limit of 7000rpm in 4th just as I cross the line, so my gearing is lower all the way.
The two boxes have the same ratios, its just the final drive that differs.
Shame it's a bit of a wait till the next Pod meet :cry: , cant wait to see if it all pays off.
GAMMYGOLFGTI said
I see![]()
Well hopefully it should all be screwed together again for GTI Inters, but the track there is far from optimal. The real tester will be Retro Car Show/GTI Festival, and I'll be aiming for 13s….
![](https://vwgolfmk1.org.uk/uploads/pbextract/825959/Dsc01960reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825959/enginein5.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825959/Dsc01957.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825959/Dsc02378reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825959/Dsc02471reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825959/Dsc02565reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825959/Dsc02600reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825959/Dsc02695reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825959/DSC02720adjreduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825959/DSC02779levelsadjcropped.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825959/Dsc03959cropped.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/825959/Dsc04425reduced.jpg)
http://www.youtube.com/watch?v=Brf68zTE7Lc
http://www.youtube.com/watch?v=YZaGhkzHklM
http://www.youtube.com/watch?v=tK-qTJACZrs
![Avatar](https://i222.photobucket.com/albums/dd103/iPod_Fixer/000177.png)
![X in the usergroup ‘Local hero’ X in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
i love that black paintworky deepy shiny thingy 8)
1983 Golf 1.3 Driver:
![](https://i222.photobucket.com/albums/dd103/iPod_Fixer/182000_zpsdfa6a837.png)
Guest user
![ThE_gOg in the usergroup ‘Old timer’ ThE_gOg in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Chris
Need your console repaired or mods done? drop me a pm
![](https://vwgolfmk1.org.uk/uploads/pbextract/826214/Dsc04781reduced.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/826309/Dsc04785reduced.jpg)
It was the broken cover for the oil level, in the end I had to chisel it off gradually from alternate sides. Once it was off I transferred the good one from the other gearbox (much easier to remove!)
![](https://vwgolfmk1.org.uk/uploads/pbextract/826309/Dsc04786reduced.jpg)
Then I refitted the friction disc and lightened flywheel. Note the aligning tool:
![](https://vwgolfmk1.org.uk/uploads/pbextract/826309/Dsc04787reduced.jpg)
These bolts get torqued up……
![](https://vwgolfmk1.org.uk/uploads/pbextract/826309/Dsc04790reduced.jpg)
to…
![](https://vwgolfmk1.org.uk/uploads/pbextract/826309/Dsc04792reduced.jpg)
Hairyarse said
Nice little torque wrench Paul! What's the setting range on it?
Its a 3/8" and goes down to something daft like 6 Nm (I can almost undo those by hand!!!), can't remember the upper end but it overlaps with my 1/2" torque wrench, ie its not big enough to do stuff like cylinder head bolts. It recently won the torque wrench group test in Car Mechanics, believe it or not its from Halfords, though its their professional line and still cost a bit.
![Avatar](https://i181.photobucket.com/albums/x300/el_sicko/Arthur-Hello.gif?t=1222180815)
![bigdave in the usergroup ‘Old timer’ bigdave in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://news.thomasnet.com/images/large/020/20980.jpg)
:wink:
