ABF on DX cabby
(In Topic #97273)
ABF on DX cabby
I know that I need 16v exhaust manifold to the conversion (Supersprint,Raceland or Scirocco 16v).Can I use my 1.8 8v gear box,or is better to use another one??Do I have to change something of the ABF motor to fit correctly,or do I have to modify things apart from fixings of the engine or adapting the 8v wiring to 16v??
parts that I cannot obtain from my DX motor or th ABF I have.
So the alternator can be the same that I have on DX.When you say "cast items" what are you refering to??Sorry but my english is not good enough to know some specific words
This motor is a 9A engine so I think there are some diferences between 9A and ABF I have from a golf mk3.The question is if I need the starter motor, alternator, water pump of the ABF engine or I can use the ones I have on DX mk1 engine.As MK1ABF says,if the alternator needs a swapping,possibly is better to put one from a 16V to fit correctly with no problems.The starter motor and water pump must be of 16v or the ones I have in DX are plug&play?The cool system with radiator can take from the DX,is it?
I also have other things as Speed front panel (sorry but I don?t know the word you use it to say),catalyzator and ?antiblock key sistem? Is this really necessary??
Water pump of ABF,mantain DX radiator,but modify the top hose to fit well.
Put a catalyzer of ABF ?and lambda sonde?.If I take away the inmobiliser,do I have to put catalyzer too??This ECU has immobilizer,so what is the best option to do??
All the rest engine mounts I can take from my GTI DX engine.
Is this correct??
The fuel pump must be from a 16v (KR for example),is it?
putting the mk2 8v gearbox,the flywheel and clutch have to be from the same box,or its possible to put the KR?s which is lightened,searching the easiest option to fit.
And what about the power steering that I have on my cabby now?Can be supported like other engine mounts or have to modify it?
I have been looking about the exhaust manifold 16v conversion.I have read that the 16v conversion manifold from Ashley?s or Raceland, fits perfectly on 9A engines,but the ABF from golf mk3 is a 16mm taller block,so it may needs modifying.Is that right?Apparently,Supersprint has one that fits with no problems on the ABF conversion.Is the only one??If I put the OEM one from Scirocco 16v or buy a manifold for a Scirocco 16v,would it fit well??
abfmk1 said
The abf went into my mk1 as it left the mk3 complete with alternator and power steering pump, although i did take a hammer to the chassis rail for a little clearance.
Did you ditch the PS Pump in the end?
is this
this two pieces set with OEM other exhaust system,is it?
