change wheel bearing tools
(In Topic #80271)
Wilson
simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
sim0n_parker said
idealy u could do with a press mate, as im sure there pressd into the hub.
simon
Bugger… thats what I read, you say idealy…??? Does that mean its possible without, just easier with ?
Wilson
other then that its striaght forward and the usal tools like socket set spanners, hammer jack axle stand copper grease when putting it back together and oh yea dont forget to absolutly coat the nuts n bolts in a real good lubricant wd or sumin close.
simon
<a href="
Early-1800 said
Is it noisey when you spin the wheel? Does the the noise change when driving around a bend or roundabout? Brothers was very noisey but when we did get it out it just had a small amount of rust on one of the rollers from water ingress. From the racket it made you would have thought it was total Kerr..nakered. Your movement might be worn lower ball joint or top mount? Are your wheel bolts tight?
Top mount etc are ok.. its def movement from in the hub area, bolts are def tight… double checked that first !
sim0n_parker said
make sure the ndriveshaft bolt aint come lose as vdubs are prone for this and thats what fooks the bearings up!
I hope so…. gotta get hold of a 30mm socket from somewhere… its difficult to buy seperate sockets !
There is a typical bearing noise the whiring noise, hard to tell which wheel its coming from though…
halfrauds do single sockets or your local parkers parts etc they sell sockets too.
simon
p.s. let us no how u get on m8
<a href="
crazycar said
jack up the wheel then shake the wheel side to side and then top to bottom if theres movement/play then thats a good sign of bearing wear
There is plenty of movement !!!!
Wilson
