horn
horn
sorry i couldnt post this in the electrical section.
all i get when i press the horn button is a click from the relay i,ve got power to the horn but no horn noise. is the horn bust or could there be something else wrong? (before i go and get a new horn)
1984 white s2 golf gti , 2006 golf gti
Make sure it has a good earth, poor earth could be enough to trigger the relay but not carry the current off.
Easy way to eliminate a faulty horn it to run 12v straight through it, if it's working you'll probably be deaf after :lol:
If the set up is twin horns connect just one and try again .
PARDON?
Typically twin horns will just pip when you hear the relay.  If this is the case and a direct 12v feed makes them blare then the wiring is old and can't deliver the power.
In this case you have three options - fit a single horn, replace the old wiring, use a second relay in the engine bay to operate the twin horns.
Crazyquiff's Mk1 Golf Parts Emporium
www.golfmk1.co.uk - you know you want to….
thanks everyone it is twin horn so i,ll try connecting one 1st. have to be on the weekend though as it is still dark when i finish work  :(
horn working again now :lol:  i ended up running a wire straight from the battery live to the horn and it works  m.o.t on friday. fingers crossed. its been off the road for almost 4 years
