thats torn it now with pics
paul_c said
bigdave said
could you not try welding a bolt to it or even sacrifice a socket and weld directly onto it?
What for? The pulley came off on its own, the main issue now is the piston/valve damage!!!
the rest of the bolt is still in there paul as for valve damage im going to be brutal and chuck the belt back on to see what happens as i was just pulling away i hit the clutch as soon as i heard the pulley pop :wink:
good luck
83 BBS MK1 GTI 69 T2 PANEL VAN i am back let the trouble begin
think im going to have to get brutal with it i dont think it will be locktited as my neighbour had the bolt out last year which is why i think its gone
i think he may have put it on on the tilt maybe
the 2.5 engine for my dads audi is?1750 for an afb 8O
these guys are near you i think just emailed them about mine but the say they have abl engines in stock
holy cow
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
As for the oil seal its a 32x47x10 (if its a 1.8 8v engine, sorry just noticed its a van!)
If not you should see three numbers as I have written them here, on your seal.
Just write them down, most engineering suppliers should be able to get them or a motor factors.
How the 3 numbers work below.
32 (ID inside diameter) 47(OD outside diameter) 10 is the depth all in mm
Chris
www.cw-se.com
"Video et taceo"
"Video et taceo"
the left handed drill bit thing sounds like a plan :wink:
Actually if you use a small drift and T**t the stub with a big hammer, the "shock" often loosens old bolts/studs, always worth a try before you go at it with a drill.
"every little helps"
www.cw-se.com
"Video et taceo"
"Video et taceo"
one question which could be of importance
which way does the thread go on the bolt left or right handed as i know vw have a knack of making things hard :wink:
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
going to do it saturday if i dont get the bolt out then a hefty hammer will be the measure of the day then i shall post said van through neighbours letterbox (thats who sold it to me)
whats it like up your end of the country looking for a weekend getaway next month
hmm welsh roads or country lanes as they are known here sounds fun :wink:
