Relay problem HELP ASAP
(In Topic #94498)
![GWtaylor in the usergroup ‘Local’ GWtaylor in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Gary
1983 GTI-Black
MY very first one AND LOVING IT!!!!!
![mcscrew in the usergroup ‘Local hero’ mcscrew in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
If he doesn't have any in stock he will be able to advise you on where to get one from…
www.golfmk1.co.uk
HTH
Rich
![Avatar](https://img110.imageshack.us/img110/4571/homerrelaxingug7.gif)
![divweir in the usergroup ‘Old timer’ divweir in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
<a><img></a><a href="Login to a private Photobucket.com album
Can anybody have a quick look at there series 2 fuse board and just comfirm that it is relay number 7 as I may have others missing as well infavt if anybody could take a quick pic of 1 actually on the car that would be super
Gary
1983 GTI-Black
![Avatar](https://img.photobucket.com/albums/v459/lakesk8/DSC00253-1.jpg)
![lakesk8 in the usergroup ‘Old timer’ lakesk8 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
You may not have a relay with just one rear fog [correct for uk on drivers side ] just a fuzed link as i said on the top of the board .
Check that fuze it should be above relay 5 .
lakesk8 said
have you got the ceramic fuse board or the blade, mines the ceremic one if its the same i'll have a look
Mine is blade fuses
1983 GTI-Black
chudd said
Should be a relay no7 for front and rear fogs. But there is also a fuze at the top of the fuze board for the fogs, should have grey white wires going to it .
I'll have a look Thanx
1983 GTI-Black
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/forks.png)
![djheap22 in the usergroup ‘Old timer’ djheap22 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
as already said relay should be no 7.
pic of my relays out of 1.8 carb, same layout I think.
info on 1982 GTI relays I have is
1 (free)
2 Inlet manifold heating (Carb) / Fuel pump (Inj) / Glow plugs (Deisel)
3 Seat belt warning system
4 Gear change up display (Formel E, GTi)
5 A/C
6 Twin horn
7 Fog lights
8 X relay
9 (free)
10 Wash-wipe interval
11 Rear windscreen wash/wipe
12 Hazard warning lights
13 Seat belt warning system
14 Seat belt warning system
15 Headlight dim-dip
16 Cold start valve
17 (free)
18 Coolant temp gauge (Inj, Diesel)
![](https://vwgolfmk1.org.uk/uploads/pbextract/785882/PA060023.jpg)
1988 1.8 carb Golf Clipper
![golf1 in the usergroup ‘Old timer’ golf1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://i161.photobucket.com/albums/t238/happymick_bucket/mz_4058519_headshot_66x66.jpg)
![happymick in the usergroup ‘Local’ happymick in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
89 MK1 GTI Cab ( Helios Blue ), 64 reg VW Transporter T30 highline, Audi A1 1.4 TFSI Sportline..
judging by that pic i got a few missingdjheap22 said
1983 GTI-Black
happymick said
I've got some relays that i rescued out of a MK2 that we got on station to practice cutting up. When you find out what number it is , let me know and if i've got one i'll send it to you.
That would be ideal that mate
1983 GTI-Black
djheap22 said
Hi,
1 (free)
5 A/C
6 Twin horn
7 Fog lights
8 X relay
9 (free)
16 Cold start valve
17 (free)
Different to the GTI model eg relay 11 missing [rear wash wipe not on Cabriolet ]. No7 relay was never fitted . Fogs UK was one rear 21watt bulb fitted to the drivers side .
Same fuze box in say Passat with top of the range bits would have had front and rear fogs and had a relay . Parts bin again , thats why your fog light switch has 2 positions . GWtaylor your fuze panel should look like this .
![](https://vwgolfmk1.org.uk/uploads/pbextract/789238/Picture229.jpg)
1983 GTI-Black
I'd always wondered about that
Rich
