Driver wiring ID please with pics
(In Topic #94627)
Can any of you driver guys nip out and identify what these wires are for on a driver engine bay loom… its not the main headlight loom - its the other one beside it
![](https://img.photobucket.com/albums/v243/gwilson16v/17012008313.jpg)
I know most of them are engine sensors but the red/black and black which run to the plastic connector has me stumped - why would it have a plug like that? Also the black and yellow running to one plug??
Also the black wire in the pic below which has three plugs on it - wots it about?
![](https://img.photobucket.com/albums/v243/gwilson16v/17012008312.jpg)
any help appreciated - should have labled these before removing them…
the only thing on the car that has 3 plugs that i can remember is the brake light switch…i used an audi pedal switch so got rid of it…
i believe the yellow and black one is for the carb or manifold /somewhere up near the bulkhead…
maybe not very helpful, but that spade connector is in clear view and im sure thats for the top of the cover, like i say all the rest is guesswork/from what i can remember
hth mate
JJ
You may have to get the haynes wiring diagram out and find the wire colours
Or try
http://volkswagen.msk.ru/index.php?p=page09_g1
Top link 'wiring diagrams' Usa but uses same colour code
Cheers ………..
i have worked out what the rest do bar that wire with the two plugs… isn't it a carb heater element???
