no indicators
(In Topic #94173)
![peelywally in the usergroup ‘Newbie’ peelywally in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
no indicators
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/snorkler.jpg)
![Tian in the usergroup ‘Local hero’ Tian in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
The hazards work off a different circuit so they can stay on with the ignition off.
Much luck with the MOT
Tian
![Avatar](https://img.photobucket.com/albums/v725/orrinb/Golfavatar.jpg)
![DyslexicDwarf in the usergroup ‘Local’ DyslexicDwarf in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
<a href="signatyar.jpg picture by orrinb - Photobucket"><img src="http://img.photobucket.com/albums/v725/orrinb/signatyar.jpg" border="0" alt="Photobucket"></a>
![dji8785 in the usergroup ‘Local’ dji8785 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
am going to try a new hazard switch, and hope for the best.
any other ideas floating about?
here for a good time, not a long time
Change the fuse anyway as it maybe faulty, mine was but gave the impression of being fine on inspection.
Could be in the stalk but I doubt it tbh.
Someone else might have a brighter idea.
Tian :dontknow:
have tried a new fuse, but that didn't work.
hopefully someone can put us out of our indicator misery once and for all.
dji8785 said
i thought the indicator lights ran into the hazard switch.
Ther hazards work off a different fuse to the indicators. They are also on a different rated fuse too, 15A.
Try disconnecting the hazard switch and see if this makes a difference, I can assure you it won't.
Tian
![Topoftherange in the usergroup ‘Local hero’ Topoftherange in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
I have had this with wipers and the horn playing up before and it cured it
i'll try the fuses again, and to clean the stalk itself.
the mystery continues.
![craggle in the usergroup ‘Regular’ craggle in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![mcscrew in the usergroup ‘Local hero’ mcscrew in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Open it up carefully and see if there are any springs inside. These hold the contacts of the switch together, and if they're missing you often get the green light on the dashboard on all the time.
I have substituted one of mine that I lost with a bit of folded paper, and it seems to work ok.
HTH
Rich
![GingerMatti in the usergroup ‘Local’ GingerMatti in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1982 1.8 GTI Mars Red
![Avatar]([IMG]http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg[/IMG])
![sim0n_parker in the usergroup ‘Old timer’ sim0n_parker in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
check this is connected, (single wire as u stated)
ive had a few hazard switchs pack up on me on my old mk1's so if u have a spare or can get access to another one try it?
i always have the last laugh ![;)](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wink.png)
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
![dubhighland in the usergroup ‘Old timer’ dubhighland in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/chess.png)
![Dilanz in the usergroup ‘Paid Member’ Dilanz in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Dilanz in the usergroup ‘Validation Required’ Dilanz in the usergroup ‘Validation Required’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
When I flick the switch to turn on the hazards all I get at a green light(stays on until I switch the hazards off) I have a 1991 cabrio. Help pls? I've brought a new switch and still have the same problem fuses all ok. Thanks
