Where do i start cleaning this weber car? PICS
![whitesta in the usergroup ‘Local’ whitesta in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://i218.photobucket.com/albums/cc158/whitesta83/DSC00175.jpg)
![Avatar]([IMG]http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg[/IMG])
![sim0n_parker in the usergroup ‘Old timer’ sim0n_parker in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
remember….dont smoke :wink:
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
Login to a private Photobucket.com album![whitesta in the usergroup ‘Local’ whitesta in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
How do i clean the jets from here, or where can i spray carb cleaner?
![](https://i218.photobucket.com/albums/cc158/whitesta83/DSC00178.jpg)
remove them 4 brass screws that are the jets, but be carefull incase there is springs or ball barings under it, just make sure nothing shoots out.
once u remove them 4 brass jets make sure all the holes are clear.
Im not convinced its the cause of my cutting out problem which i have had for the last 4 months, cutting out randomly hot or cold sometimes on idle and sometimes driving and lose power and sounds nasty and hollowy, then pull over. Then starts few mins later. Annoying me alot.
Any ideas?
sounds quite like the pierburg symptons when the fuel freezes in the carb.
have u go a k and n or is it standerd filter? make sure the hot air diverter is open if it is?
changed the fuel filter recently?
checkd the filler neck for rust?
The weber carb has the original airbox fitted to it with the oil breather pipe fitted. Im not sure about the air flap in the original airbox pipe, shall i check that it is feeding from the cold start then?
I have checked the fuel filter because it is glass and is clean, also looked into the fuel tank and filler neck looks mint, reckon its new. and blown through all the fuel pipes all clear. Also the weber pre bowl filter was all clean so no restriction to the carb at all.
I have also replaced the dizzy cap leads plugs and rotor arm.
Any more suggestions most appreciated mate.
james
ill have a think, and see if i can think of anything else.
simon
