Erratic speedo and loud noise
(In Topic #94053)
![trickyharris in the usergroup ‘Local’ trickyharris in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
after a bit of advise. My mk1, 1991, gti cab makes this loud noise and the speedo goes nuts when (norm in the morning - cold?) I go over 60 - 70. The speedo then jumps between 90 - 110 and the noise is loud and constent. Then as slow the noise gradually fades and when i get to 20- the noise stops and the speedo returns to normal. Anyone any ideas? - speedo drive? - if so is this a 'big' job.
Has anyone else experienced this? Cheers
![tallpete in the usergroup ‘Old timer’ tallpete in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Reach up behind the instruments, you might need to unscrew the trays to get to it. I am afraid I can't remember how easy it is to reach on the newer dashes, It's so simple on the early ones.
The speedo cable screws in behind clocks in the same place as the centre of the speedo dial.
It's a normal screw fitting.
Peter.
1980 1600 GTI, daily driver.
Thanks again
