Engine Cleaning
(In Topic #94004)
![Hartchez in the usergroup ‘Newbie’ Hartchez in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Engine Cleaning
Many thanks, Jeannie
Re: Engine Cleaning
Hartchez said
Hi, can anyone advise of the best way of cleaning the inside of my engine. I have a MK 1 Cabrio which has done 75k. Tappets are a little noisy, nothing major, but I wanna stop them progressing further. I am a bit wary of using oil flushes, someone said about doing an oil change and then mixing the oil with a quart of transmission fluid as this "gently" cleans the engine?
Indeed, you can use ATF as an alternative to engine flush. Important point is that you do if before the oil change, not after, and use it in the same way as an engine flush, ie add it to the oil, run the engine gently, then do the change.
Why are you wary of using an engine flush? If anything I'd have thought a proper flush is better than the ATF trick, hence I always do a flush on every oil change.
Oil Flush
http://autotechrepair.suite101.com/article.cfm/040206
Wary as I dont think the car has ever been flushed before and is some 20 years young! thought it may cause problems so was looking at a more subtle cleaning method.
Thanks for you help/continued comments, much appreciated. Jeannie
Couple of extracts:
The only ones who do recommend flushing as a maintenance procedure are the companies that sell the flush machines and the shops that buy them.
Hmmm, typical $$$ capitalism here…..
I know this since I recently appeared as a witness in a lawsuit where a person was sold an engine flush that destroyed his engine.
$$$ x 3 hmmmm…..
Oil Flush
Kind regards, Jeannie
