fuel pump
(In Topic #93864)
![Avatar](https://img110.imageshack.us/img110/4571/homerrelaxingug7.gif)
![divweir in the usergroup ‘Old timer’ divweir in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
fuel pump
<a><img></a><a href="Login to a private Photobucket.com album
![bytor in the usergroup ‘Local’ bytor in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
The pump does make a buzzing noise anyway - however it can be a sign when it gets louder that it's about to go.
If the car is spluttering there could be lots of causes. Again - do a search on the forum.
![Avatar](https://img.photobucket.com/albums/v459/lakesk8/DSC00253-1.jpg)
![lakesk8 in the usergroup ‘Old timer’ lakesk8 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
has anyone ever re earthed their fuel pump? i mean run a new line straight to the battery or some where else?
2003 MKIV Golf PD150 GT TDI
lakesk8 said
is it easy to get to the wiring on the tin top gti fuel pump?
Bad idea to bypass the original wiring and relay, except for test purposes. The relay has a 5th connector which is the tach signal from the coil, this is to prevent the fuel pump running on if the engine stops but the ignition is still on (eg in an accident situation).
