Replacing a Pierburg carb with manual weber
(In Topic #93786)
Questions
What do I change to?
What should I pay new/2nd hand?
How hard is it to do yourself?
Is there anyway to service/overhaul the Pierburg before splashing the cash?
Con
http://www.clubgti.co.…m/showthread.php?t=144497
http://www.clubgti.com…hlight=weber+32%2F34+carb
Ebay is a good place to look for the carb, just make sure you DEFO get all the brackets and the manual choke cable assembly, plus a weber service kit, basically new gaskets etc (also from ebay, just do a search for them) also make sure the weber is jetted correctly for your engine ie for a 1.6 or a 1.8 as the jets are different sizes !
Also search on here for help
Plus fit a new inlet manifold rubber flange as you defo dont want any new air leaks.
I'm also fitting a new accelerator cable at the same time.
hope that helps !
G60
Anyone done a 1457cc?
Yorkshire Region Host
Mk1 Cabriolet 1500 (under resto)
Mk1 GTI
Mk1 GTI
I had the carb off and cleaned it up and checked all the hoses. It seems OK. Might try the service kit though. For that price you can't loose.
I put it all back together and hey presto it ran. Today no start. I think I might have the leads in the wrong order as well.
sh*t
Can webers be automatic as well as manual? Cheers
search for carbs you'll find his shop
it was from some weber shop on the net
just type in weber see what you get . hope that helps a bit
fitting a weber
mk1 work in progress
Can you post up a pic of the carb in place ?
Could also try a search on the forum !
G60
also on the weber there seems to be a little rod that isnt connected to anything and when you press it in it stalls the car is this the problem why my cars cutting out when i let the revs die down????? :cry: :cry:
As for the Little Rod im not sure what you mean soz post a pic of it if you can ?? cheers
G60
This one below shows how i've just re-joined the coolant hose's together on the in-let manifold, as the weber doesnt need coolant for its choke as it has the manual one!
G60
the linkrod is on the left will examine tomorow when im at work anf get those pics on as therell explain it easier ta bud
G60
G60
