Found the petrol leak, but where actually is it? *photo*
(In Topic #93429)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/dog.png)
![Concorde_Rules in the usergroup ‘Local’ Concorde_Rules in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.thunder-keep.co.uk%2Fsite%2Fgolf_petrol_leak.jpg)
Well those pipes are soaked in petrol, so:
1. Where could it be coming from?
2. Easy fix/time required?
3. Parts needed (if any)?
Also sometimes the engine starts fine sometimes it needs to turn over, stop and then it will start first time, related?
Cheers guys
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Golf%20Ava5.jpg)
![markwon in the usergroup ‘Local hero’ markwon in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
1983 1100 C
1983 1100 C
![Avatar](https://i78.photobucket.com/albums/j95/citigolf_2006/Avatar0.gif)
![Bert in the usergroup ‘Local hero’ Bert in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Bert in the usergroup ‘Paid Member’ Bert in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
And is it standard part that I can get at any parts shop or do I need to go to German and Swedish?
Edit: Which ones do I need? :
18600 VAC HOSE General Use 2.00 Add
18602 FUEL HOSE 5mm General Use 2.00 Add
18603 BRAIDED FUEL HOSE 5mm General Use 5.00 Add
18604 FUEL/EXP.TANK HOSE 7mm General Use 3.00 Add
18606 FUEL HOSE 9mm General Use 4.70 Add
18610 JUBILEE CLIP-FUEL HOSE General Use 5mm Fuel Hose 0.50 Add
18611 JUBILEE CLIP-FUEL HOSE General Use 7mm Fuel Hose
Im not quite sure where they go :dontknow: Ideas?
![Prowler in the usergroup ‘Old timer’ Prowler in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.vwgolfmk1.co.uk%2Fimages%2FLiftpump%2Fcover.jpg)
here are the other ends….
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.vwgolfmk1.co.uk%2Fimages%2FLiftpump%2Fconnections.jpg)
I should be able to fix it today then
5mm Braided or 7mm fuel/exp.tank hose?
Had a measure and the metal pipe to the front of the car seems to be 7mm :dontknow:
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.vwgolfmk1.info%2Ffuel%2Ftankpumpfuel.jpg)
And I changed it myself, in the wind and rain, and, SHE LIVES!!!!
AHahahaha
I feel so happy.
Not the first time I've worked on a car (replaced Volvo 850 Estates Damper mount).
But she lives and she seems much smoother!
However how fast should it idle? Its about 500/600 RPM and seems very close to stalling, any way of getting that up to say 800?
Cheers for your help lads
