car refuses to do over 60 in third
(In Topic #93255)
![AntF in the usergroup ‘Old timer’ AntF in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I know its fuel related, but there is not any rust in the tank, its not HT leads, distributor etc (these were replaced less than 400 miles ago) but i need to know if this is because there is the possibility something is stuck in the tank?
It only does this every so often as well, for example, i just changed the in line fuel filter and it did not do it, but im pretty sure if i take it out tomorrow, the same thing will happen.
If it is something caught in the tank, can i get at it from under the seat where the fuel lines start?
Any help appreciated
Alex
![woZa in the usergroup ‘Old timer’ woZa in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
When you have done this post back your findings and we can take it from there.
Also timing might be out (could have slipped a tooth) so check that too.
Also check the throttle cable is actually opening the butterflies in the throttle body fully.
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Topoftherange in the usergroup ‘Local hero’ Topoftherange in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
my 1.8 Gti cab dont do much more than that
![Avatar](https://i245.photobucket.com/albums/gg80/novocaine10/n731220548_174194_274-1.jpg)
![novocaine in the usergroup ‘Local hero’ novocaine in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
have a look at the breather on the tank and the fuel cap it sounds like fuel starvation to me but not blocked more like vacuum build up.
my VR6 only does 110 mph in 3rd………it gets there quick though :roll:
the car is pretty fast actually like novocaine said, and though i dont push it like this very often, it definitely used to have no problem going this speed in third and then going on to crack 105 mph, that vr6 sounds mental! i want one so much
i will have a look at the weekend anyways
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Golf%20Ava5.jpg)
![markwon in the usergroup ‘Local hero’ markwon in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Not being lippy but does a 1.5 go over 65 mph in 3rd normally
Sounds like a four speed, third gear will be somewhat longer than in a 5 speed. My 4 speed 1.1 will do 60 mph in 3rd, mind you my 5 speed 1.6 GTI will pull 75mph in 3rd. What rpm are you losing speed at, what happens at that rpm in 2nd gear?
1983 1100 C
1983 1100 C
