Fuel Pump
Fuel Pump
????'ss later, and now have m.o.t !!!
Fuel pump still making a bad noise, changed the one inside the fuel tank( think this is a sender unit ), but still the car cuts out while driving?? Must be the fuel pump under the car??
Is there a link for changing this part?, 1987 golf cab is the car.
Looked for relay, carn't seem to find it
And last of all, how much are they to buy? the local vw place is very high in there pricing of parts? cost me ?35.00 just for the pump in the tank.
 :cry:
Cheers for any help, in liverpool area t.mora, so if you have one cheap, let me know ( or b.ham area )
Daz1971
Car Parts & Spares -- Buy Online with Fast UK Delivery | GSF Car Parts is your best bet, i got the pump and relay for about 75ish pounds delivered, they do have stores everywhere too if you have a look on there web page!
White cabriolet Gti 16 valve
might try euro car parts aswell….they're on line.
Jo
Mk 1, 1983 1300 Blue LONG LIVE TAFY
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://i93.photobucket.com/albums/l58/peg1_photo/signature-1.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Cheers, will take a look..
Is it easy to fit ?
yup sure is!
:P  great will try and get one t.mora, just want to have a good ride out while its dry !!
Many thanks
Hey I'm a girl and I did mine..
It is possibly the easiest job to do….
Peg
Jo
lol,
Going for a shot in the dark tomorrow… there is a wire going from fuse 19, then its joined straight to the fuel pump wire under stearing wheel ?
I have taken relay out of number ' 2 ' and the pump / car still runs  :dontknow: take the wire off the front of fuse 19, pump stops.
What i think is… someone please tell me if im wrong…..because there is a constant feed to the petrol pump and by-passing the relay, its causing problems ?
Hopefully i will save ?? on not getting a new pump.
This is my last problem ( apart from a new roof ! )
Your help is way better than a haynes !!!
Daz
I think you and i have the same problem daz, I've changed fuel pump,relay and filter and its still cuts out! This has happened to the 8v and 16v engine that have been in my car (16v is still in) I can't see the problem being electrical to be honest. What i suspect it is, is the supply from the fuel tank to the fuel pump, i've heard the filler neck corrodes and blocks the pipe and is a common problem. Can anyone else verify this?
cabrio_dj,does your pump make a ' buzzing ' noise on the 1st turn of the key, then when the car starts its fine for a bit, then buzzi's….. and a bit splutterie ???
The problem with changing the fuel pump, filter etc is you're addressing the downstream consequence of contaminated fuel, not the root cause. The worst case scenario is that you could ruin a brand new fuel pump. There's no easy way, but you need to make sure the fuel tank and filler neck aren't rusty and have no rust/dirt in them.
Just had a new fuel tank fitted, fuel sender unit, filler is fine to.  :dontknow:
Make sure you look/check the lift pump in the tank - fitted to cabs '84 on I think - Is the problem worse with 1/4 tank than full?
Crazyquiff's Mk1 Golf Parts Emporium
www.golfmk1.co.uk - you know you want to….
Thats what the guy said who sold the car to me, he said put ?25 petrol in and the noise stops ?!!!??  i have around 1/4 in at moment, does seem worse when reversing down drive ! have had a new / 2nd hand sender unit ? think its dodgy too ??what can i do.? Still have to sort out the relay though !!
Thinking about it, had a little drive last night and up the hill it cut out on me… mmmm
cheers mate
If you have a lift pump - need to know year. It is mounted on the fuel sender - only about ?35 quid new - I can supply one.
You can pull it out and test that it can pump fuel.  They make a raket when duff which sounds like the main fuel pump being noisy.
Rich
Yes thats a sympton of mine!!! (1986 gti btw) Where abouts is the lift pump? is it easily accessed?
You have to withdraw the fuel sender unit accessed under the seat under the round plate - can be stuck so don't hit with a hammer or you will break it.
The lift pump is part of the sender assembly
Removed direct wire to fuel pump,fitted loose one under car back to fuel pump ( original wire i think ) fitted new fuel pump relay and HEY !! Car started, no noise from fuel pump at all !! :D
Car drove for 5 mins, started loosing revs, around 500/600  got back home… car cut out on drive :banghead:
Just turns over now, does not start now.
Any ideas, will start from scratch in morning !
Daz
As before.
