Fuel Pump
(In Topic #92595)
![daz1971 in the usergroup ‘Paid Member’ daz1971 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![daz1971 in the usergroup ‘Local hero’ daz1971 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Fuel Pump
Fuel pump still making a bad noise, changed the one inside the fuel tank( think this is a sender unit ), but still the car cuts out while driving?? Must be the fuel pump under the car??
Is there a link for changing this part?, 1987 golf cab is the car.
Looked for relay, carn't seem to find it
And last of all, how much are they to buy? the local vw place is very high in there pricing of parts? cost me ?35.00 just for the pump in the tank.
:cry:
Cheers for any help, in liverpool area t.mora, so if you have one cheap, let me know ( or b.ham area )
Daz1971
![cabrio_dj in the usergroup ‘Local’ cabrio_dj in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
White cabriolet Gti 16 valve
![peg1 in the usergroup ‘Old timer’ peg1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Jo
Mk 1, 1983 1300 Blue LONG LIVE TAFY
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://i93.photobucket.com/albums/l58/peg1_photo/signature-1.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
It is possibly the easiest job to do….
Peg
Jo
Going for a shot in the dark tomorrow… there is a wire going from fuse 19, then its joined straight to the fuel pump wire under stearing wheel ?
I have taken relay out of number ' 2 ' and the pump / car still runs :dontknow: take the wire off the front of fuse 19, pump stops.
What i think is… someone please tell me if im wrong…..because there is a constant feed to the petrol pump and by-passing the relay, its causing problems ?
Hopefully i will save ?? on not getting a new pump.
This is my last problem ( apart from a new roof ! )
Your help is way better than a haynes !!!
Daz
Thinking about it, had a little drive last night and up the hill it cut out on me… mmmm
cheers mate
You can pull it out and test that it can pump fuel. They make a raket when duff which sounds like the main fuel pump being noisy.
Rich
crazyquiff said
Make sure you look/check the lift pump in the tank - fitted to cabs '84 on I think - Is the problem worse with 1/4 tank than full?
Yes thats a sympton of mine!!! (1986 gti btw) Where abouts is the lift pump? is it easily accessed?
Car drove for 5 mins, started loosing revs, around 500/600 got back home… car cut out on drive
Just turns over now, does not start now.
Any ideas, will start from scratch in morning !
Daz
