16v abf dizzy cap and fire order.
(In Topic #92099)
![sciroccotune in the usergroup ‘Regular’ sciroccotune in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I followed the firing order from the FAQ that is going around but it doesn't seem right.
Im sure i have seen a modified picture showing the correct firing order.
any one got any input on the order teh leads should com off the abf cap?
i think it should look like this from above
24
13
but the faq has it as
31
42
If you ask me the first plug to spark should be no1 just after no 1 bore is at tdc?
input is appreciated.
![cabrio_dj in the usergroup ‘Local’ cabrio_dj in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
White cabriolet Gti 16 valve
think its the first one also as managed to get some life out of it with the help of some cold start spray.
Starting to think that although the injectors spray at full wack on the metering flap they are not giving enough fuel when the flap is only up a tiny bit - i.e trying to start etc.
maybe get some new injectors - not like i have not spent enough all ready
8)
![](https://www.pbase.com/dgawen/image/56256872.jpg)
![](https://www.pbase.com/dgawen/image/56256869.jpg)
that'll be mine! And you're right, I haven't labeled it in Cylinder Order.
When I labeled it I was just doing it for reference between the two images, I can't believe it never occured to me to refer to them in conventional cylinder order.
Also can't believe noones pointed it out to me before!
Anyway, apologies thats my bad, i'll change it!.
Dave
Nothing to say sorry about! brill FAQ - just confused me is all
Mainly as i started with no cap so noting to refer to. 8)
![mk1ash in the usergroup ‘Local’ mk1ash in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
any help would be great
http://www.pbase.com/dgawen/dizzy_cap_change
theres other options but I can't be arsed to find the links right now…
To be honest you're best off doing the valver m/c and servo change anyway, doesn't cost much.
![](https://www.pbase.com/image/56256873.jpg)
![](https://www.pbase.com/dgawen/image/87896839/medium.jpg)
![](https://www.pbase.com/dgawen/image/87896837/medium.jpg)
check out my build thread. 8)
so all is good thanks for the help
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fi34.tinypic.com%2F2466gq1.jpg)
![Illy1983 in the usergroup ‘Local’ Illy1983 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
do the numbers on the dizzy caps refer to the cylinders the HT leads go to?
<a> <img></a>
![bonus85 in the usergroup ‘Local’ bonus85 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
With the ABF cap, it will just pop and grunt on cranking. With the standard cap it fires up and runs for a few seconds then dies, but that is with the dizzy right on the end of its adjustment.
I have had KR cams fitted. All new ignition parts.
Any help??
