mk 1 gti cold start fault ?
(In Topic #91944)
got a problem with my car when its cold !
it starts first time but wont idle until its warm ? it will stay running if you hold the revs up but as soon as you let the revs die it cuts out ! once warm it idles fine.. any suggestions ? its a mk 1 gti 1.8..
thanks
how about leaky injector seals?
wouldn't that affect it when it is warm as well ??spaceace said
starter for 10;
I'ts easy to check, just pop 'em out. the o rings shouldn't cracked or shrunk.
i have a spare WUR that im tempted to chuck on, but ill also have a butches at the injector seals
HTH.
bpd said
i have this problem also (on a 16v engine), cuts out without throttle on initial cold start, however it idles fine after about 30/40 seconds of keeping the revs up, it then settles and idles fine. Also once the engine is warm, will start and idle ok first time. not sure how blind i am being…but where/what exactly is the aux air valve? Thanks.
A lot of the 16v conversions don't fit the aav or iac so you may not have either fitted… (aav is off the mk1, iac is off the 16v).
aav is at the back of the manifold on the off side (rear left as you look at front of car.
