83' Lhasa Green Mk1 GTi
(In Topic #91315)
![Lhasamk183 in the usergroup ‘Newbie’ Lhasamk183 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
New Parts (All done in past 18 months)
Top Mounts (VAG)
G-Max Lowered Suspension (Shocks & Springs -40mm)
Powerflex Bump Stops (Front)
Golf Rallye Bump stops (Rear)
Alloy Top Strut Brace
Full Jetex Exhaust System
Fuel Lines (Part replaced)
Rear Brake Lines Replaced
Recent Brake Overhaul
Front Splitter
Side Decals
Black Plastic Side stripes
Wheel bearing F/OS & R/OS
Front lower vallance prof replaced and painted last year
Exterior
No Dents
Good Clean Paint work
Matt Black & Lhasa Green Bonnet (both will be included in sale if desired)
Some light rust on the passenger side sill towards the back (Didn't affect MOT)
Rust spot on the rear panel toe eye area
Fuel Filler neck is solid as is spare wheel well
Aftermarket sunroof, no leaks!
Interior
Standard gti interior with green stripes
Headlining is complete with no snags or rips
Usual wear on drivers seat bolster
Passenger seat and back seat in excellent condition with no holes
Dash is complete with No Holes as is parcel shelf
Engine
1.8 GTI Engine, still pulls strong through the gears
Doesn't smoke or use excessive oil
Bad Points
Buzzing Indicator Relay (Possible Faulty Earth)
ATS Cups ARE NOT included in the sale (Standard 9 spokes are)
Rear Wiper & Reverse Lights Don't work
Call me on 07946 334187
Looking for ?1500 ono
Now for the pics..
![](https://vwgolfmk1.org.uk/uploads/pbextract/758572/Mk1003.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/758572/Mk1006.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/758572/Mk1005.jpg)
![Avatar](https://i118.photobucket.com/albums/o118/kriss_025/cammy22-80x80.jpg)
![kriss in the usergroup ‘Old timer’ kriss in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Wasn't she on ebay a few weeks/months ago :dontknow:
1991 MK2 Golf G60 20VT
1991 MK2 Golf GTI 16V Oak Green
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
![el_sicko in the usergroup ‘Local’ el_sicko in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Cheers for the comms.
Car is based in Bristol.
Edit: No shes not a campaign, a late A plate 1.8 gti
![Avatar](https://img.photobucket.com/albums/v725/orrinb/Golfavatar.jpg)
![DyslexicDwarf in the usergroup ‘Local’ DyslexicDwarf in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
thanks
<a href="signatyar.jpg picture by orrinb - Photobucket"><img src="http://img.photobucket.com/albums/v725/orrinb/signatyar.jpg" border="0" alt="Photobucket"></a>
![huw169 in the usergroup ‘Paid Member’ huw169 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![huw169 in the usergroup ‘Old timer’ huw169 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://s84.photobucket.com/albums/k13/pink-teg/?action=view¤t=DSC00321.jpg)
![fue in the usergroup ‘Regular’ fue in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
hi m8
can i come to c it in the morning im in cardiff ,so not far
fue
16v mk1
![Tobiasdangel in the usergroup ‘Regular’ Tobiasdangel in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/764804/DSC02283.jpg)
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
![LuckyStrike in the usergroup ‘Regular’ LuckyStrike in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I went to view this car in Bristol. The sunroof has leaked so badly the carpets are sodden. The clutch cable has come through the bulkhead and has had a bodge repair with metalweld. Its got a battery cut off switch installed really badly and the interior has loads of trim missing or half repaired with dodgy screws and the like.
The engine is strong though! From the outside it looks ok, its only when you look closely…
Ben
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
It's a 24 year old car which has been reduced to ?1250 - What do you expect? A minter… :dontknow:
Sorry for the rant. If you are genuine and know what your talking about when it comes to mk1's call 07946 334187 as I am not on-line very often.
