injector
(In Topic #90948)
injector
driving me mad
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://img.photobucket.com/albums/v312/biggaz/hezzasig.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
wvw said
First thing I did. Think I might have a compression problem in that cylander :cry: It's that bad bad you can pull it out when the engine is running. Hope this info aids you guys helping me
Injectors don't go into the cylinder, they go into the inlet manifold or the head, before the valves. So they're always under vacuum, which will prevent them coming out. (Unless its turbo/supercharged).
engine is running, the other three I can't
wvw said
This I know but not in this case there is almost no vacuum where the injector sits thats why I said you can pull it out with your fingers when the
There's no vacuum because your seals have gone! As above, replace the seals and you should be fine.
To remove them, you need an allen key (cant remember size sorry, big though) and they simply screw out. Pop a new one in and thats done.
You should be able to see the condition of the insert cup once the injector is pulled, the inserts are ony ?2-3 iirc.
hth
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
