Ive had enough of K-Jet
(In Topic #90868)
Stick with it, its great once sorted.
Ive had a few problems recently but i still quite like it, just get to know it. :wink:
What problems are you having?
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://img.photobucket.com/albums/v312/biggaz/hezzasig.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
Injectors
Fuel Filter
Filler neck
Tank
Fuel Filter
Metering head
The car is almost impossible to start and once running will run smooth at 1/4 to 1/2 throttle but anymore than that it will misfire and splutter.
I?ve spoke with Crazyquiff after Paul_c said it my be just as much trouble getting carbs running and ordered a 2nd hand WUR and 4 injector fuel lines as he said it may be possible the rubber inside one has split and blocking the flow when put under load.
I?ve also just taken the 5th injector out and there is no fuel coming out when started from cold just a tiny dribble.
This page on mechanical fuel injection is very handy to gain an understanding of each component and how it works. This should help trouble-shooting immensely.
Then have a crack at Prowler's Injector Test, as it's commonly referred to on here.
That should help you diagnose your problem more accurately.
HTH
Rich
When i removed the old WUR there was a solid lump of rust that covered the mesh filter and the line from the metering head was full of it, was a wonder the car even ran at all
Well done, got there eventually eh? bet your pleased! :wink:
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
biggaz said
ahh, now thats good to hear!
Soo pleased i did 10 quid in petrol last night thrashing her about ops: , i forgot how much fun they are
