injectors? How do you replace....
(In Topic #90627)
I was told this "could" be blocked/poor injectors. Tried running som injector cleaner through but no luck there.
Today i sprayed some carb cleaner down at the injectors while the car was running and on about 3 of them the cars idle dropped about 3-400 revs at least :dontknow: Does this indicate that there is a leak there? Also is it likely to be the seals if they were affecting the idle whilst still seated?
The idle is now very high because i cleaned out the Throttle body which was pretty thick of crap, when refitted they idle went from 1k - 2k :dontknow: :dontknow: The idle screw on the rear of throttle body is closed all the way so i can only raise the idle not drop it.
BTW, was gonna look at the injector test but dont have anything to read PDF's lol :roll:
ANY help lol PLEASE!
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://img.photobucket.com/albums/v312/biggaz/hezzasig.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
Re: injectors? How do you replace....
http://ardownload.adobe.com/pub/adobe/reader/win/8.x/8.1/enu/AdbeRdr810_en_US.exe
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
Im thinking the engine normally revs higher when you find a leak using carb cleaner etc? mine dropped? :roll:
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
