anyone actually FIXED a oil buzzer problem?
(In Topic #90562)
![biggaz in the usergroup ‘Local’ biggaz in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Anyone had similar problem and actually fixed it, read up on some of the possible causes but if you have sorted yours, please let me know what you done.
Replaced the filter housing switch (white one) didnt realise there was one on the block so shall i try replacing that too? That ones black? Eurocarparts list them in colours, so is it the same part as the other switch but different colour?
REALLY annoying me now!
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://img.photobucket.com/albums/v312/biggaz/hezzasig.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
![wooders in the usergroup ‘Local hero’ wooders in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![boogaloo in the usergroup ‘Paid Member’ boogaloo in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![boogaloo in the usergroup ‘Local’ boogaloo in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
wooders said
i whacked the dashboard and temperarily fixed one
thats how i fixed mine (after changing both oil pressure sensors,oil pump,fitting VDO gauges,having minor nervous breakdown)wack the dash as soon as the light comes on if it goes out its something to do with the instrument panel.also worth checking the earth lead to the rocker cover (if fitted) good luck
1983 lhasa green GTI
1982 lemon yellow CL
Member 125 - 2005
![mk1jim in the usergroup ‘Paid Member’ mk1jim in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![mk1jim in the usergroup ‘Local hero’ mk1jim in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Early 1800….
How exactly do i check the oil pressure? Ive got a oil press gauge in there but not wired in, is it simply a case of running a wire to the block pressure switch or oil filter switch? Also leave both terminals on or disconnect the other when replaced with the gauge wire?
thanks again.
gary
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
Didnt help anyway, still the same.
Then checked the brown earth to the rocker, pretty much fell off, so extended it and replaced with new terminal, it seems *better* might just be me but didnt seem to come on as often? Would this earth cause trouble with the light and buzzer? Only comes on though at certain revs remember?
Also my handbrake light has started flashing a bit, usually at low revs, seems like a poor connection, flickering….
Could these be linked?
ITS DOING ME IN! :dontknow:
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
Re: it only going off at certian revs, see;
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=1325&highlight=oil+switch
A friendly garage might be able to test the pressure for you :dontknow:
The hand brake light is also a warning from the brake fluid res, check its no too low.
will check the wire to the switch at handbrake, sure my old one was dodgy there.
I might look into a gauge sender, any links to where i can get them?
Also going to see about a pressure check, sorry but what should it be?
thanks again. gaz
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
![Nev in the usergroup ‘Regular’ Nev in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![abfmk1 in the usergroup ‘Local hero’ abfmk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Oldfart in the usergroup ‘Local’ Oldfart in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![jamiegolf in the usergroup ‘Old timer’ jamiegolf in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
i changed my clocks last summer as it had a set in it with dodgy white dials!! so i fitted a set of standard ones and as soon as i revved it above 2000 rpm the buzzer went off. so i swaped the L shaped board on the back of the clocks and it was fine after that. on closer inspection of the old L board it looked like it had blown a resistor. there is a link on here i think on how to change it or it might be on clubgti.
good luck!!!
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
