HELP
HELP
me and budge have been trying to get his car going but there is a problem
i can get it running by putting fuel down the inlet but it wont run on its own, tryed two metreinf heads, two fuel pumps,
there is no fuel cumming out of the injectors atall
HELP US
Fuel pressure test?
its got pressure at the metering head, cos it squirited me wen i undid the bolt on the filter,
or is that not a good test?
Its not accurate enough. How do you know the pressure is enough to open the injectors?
so wot u think will be the problem if not enough pressure thx budge
Fuel pump, accumulator, or fuel lines, or fuel filter.
Are you charging him your normal rate for a fix, then?
she is running at last
What was it then?
foxymk1 said
?2.73
+vat?
