k-jet/wont tick over and misfires
(In Topic #89508)
if any one can help that would be great
fumes are exhaust yes? not petrol
doubt running lean would cause a misfire unless it was superdooper lean.
the haynes gives a good description on co adjustment.
i dont know if runnin too rich could cause a misfire? to explain the fumes…
more info required!!
rebuild in progress....
and yes im talking about exhaust fumes.
im pritty sure its running lean just goin by what other people have said but obv not 100% sure.
when you are altering mixture screw you should here a change in engine….
you will need to adjust your idle at the tb
if you dont have a gas analyser you can get it pretty close using the brake pedal tip i put up a while ago search 'mixture'
k-jet
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
have u readjusted the mixture since all the new parts went on?
theres gonna be an easy solution to this problem,
its an easy system (till something goes wrong)
have u seen this ?
Domain parking page
just to recap.
new:
plugs
ht leads
dizzy cap and rotor
coil
fuel pump
accumulator
fuel filter
metering head??
clean tank
clean injectors
it runs for a few minutes then splutters to a stop, can u keep it goin by revvin it??
have u cleaned the fuel lines?
only other issue i can imagine could be the wur,
after all the stuff youve replaced already, if you can sort this your gonna have one sweet engine i reckon :wink:
when it does run for its 3/4mins, it runs nice yes?
the wur richens the mixture on start up. maybe its still runnin too lean, so when the wur switches off, the mixture leans out too far? and stalls it.
