Rusty filler neck in 1991 Cabriolet.
:? Having just bought my 1991 Cabriolet , I notice that the fuel filler neck has rusted and has a hole in it. I believe it is a fairly common problem in these. I am wondering where I can go about ordering a replacement and what is involved in replacing same. A friend has suggested that a replacement unit could be made up .
Seanie
Seanie,
'Better to wear out than rust out'
Hi Seanie.
Its pretty hard to get hold of a cabbie filler neck nowadays.  Normally you'd have to get one fabricated.  The best way is to source a tintop filler neck and adjust that (I think it involves cutting some of the bottom of and using some rubber tubing).  You should be able to get a filler neck from Crazyquiff at www.golfmk1.co.uk
Mk1 GTi White Cab '86
Mk4 TDi
I could be wrong, but GSF seem to list them
29320      FUEL FILLER NECK      G1C >84 (>Ch.15E011290)      33.00
29320    FUEL FILLER NECK    G1 >12/83    33.00
29321    FUEL FILLER NECK    G1C 84> (Ch.15ZEK011291>)    96.00
the latter being gold plated
:D  Looks good but have GSF a website ?
Seanie,
http://www.gsfcarparts.com/
1990 MX5 Mazda
2003 VW Passat 130 Sport
Sylva Fury 'blade powered…
We got a filler neck for a 83 cabby from GSF in Norwich last year no probs.  I would try gsf before fabricating.
Yorkshire Region Host
Mk1 Cabriolet 1500 (under resto)
Mk1 GTI
:) Yeah would be easier than fabricating. Am wondering if the 29320 that someone mentioned earlier is the ordinary Golf . If so from what I gather this one needs to have some adjustments made. Do you know what number unit you ordered. ?
Seanie,
shawnee mate, despite the fact you haven't uploaded any photos of the new baby yet, I'm about to write a "how to" for absolute noobs on replacing this pipe, using a tintop pipe, i did it today and honestly, I am the least mechanical minded person you ever met(though i'm working on it!)
Check it…
hope u and cabby are good!
:banghead: Finally got round to getting time to take pics and do some uploading. However it seems there is a prob with uploading pics at present and the facility is removed. However I have the pics and will load when the system is back.
Seanie,
Shawnee you have to host your pics now, have a read of THIS
