MK1 8v and MK1 16v converion exhaust questions
(In Topic #87332)
While not as big a choice as is available where suspensions are concerned, what are the recommended exhaust systems for a
1) MK1 8v with a gas flowed head and Kent GS1 cam?
2) MK1 16v conversion with Scirocco exhaust manifold?
I was thinking of Jetex from TSR in both cases although I'm sure the 16v may need more flow.
Any comments on exhaust manifolds would be helpful although as I am not going wild in terms of tuning I wonder whether the cost v gain on a 4 branch is really worth it.
I also don't want to sound like a Civic but deep toned burble would be nice 8)
Advice and supplier info appreciated.
MK1 Golf Gti - Mars Red Campaign / MK2 Golf Rallye SE/ MK2 Golf Gti - Black 16v (small bumper) / Corrado - Red G60 / Porsche 911 (Daily)
exh
as you said, the standard manifolds ain't that bad and I've seen on rollers that the claims of most manufactures, note most, don't deliver as big an increase as claimed.
My core questions were relating to exhaust systems so any other takers?
HOWEVER - for a Mk1, you MUST swap the manifold because the space restriction doesn't allow the stock 16V one to be fitted. So there's no comparison to be made…..
As far as the exhaust system goes, 2?" is said to give most power, but because its so wide its not optimal for driveability or middle revs, only at WOT and the high end of the rev range. 2 1/4" (like the Ashley system) is ideal. Also matching the manifold to the exhaust system prevents any problems with mismatch during fitting and avoids improvised connections which might provide a flow restriction and reduce power.
I never really researched 8V manifolds, so I guess someone else will have to tell you about those…
exh
The jetex is 2 1/4 as far as I know so maybe I should just go for that as it is tried and tested for several years?
exh
