Fueling problems
(In Topic #87102)
Fueling problems
The car stopped the other day and hasn't started since, checked we had spark, checked the fuel pump relay and that works (what number is it just to be sure???)
Emptied the fuel filter out and turned over the engine, but no sudden feed of fuel from the tank. Put a direct power feed on to the fuel pump and all it does is pulse on and off very quickly unless you break the feed and re-connect, then the pump pulses more frequently, slowly pushing fuel into the filter.
Is the pump supposed to run continuously or does it work by pulseing fuel up the lines??
Can't think what else could be causing the issue but for a faulty fuel pump, but the problem is it was brand new 1300 miles ago, so it concerns me that one would die so quickly
Thanks in advance of your help
<html>
http://i75.photobucket.com/albums/i288/Fordyx/cf416f53.jpg</html>
Even with a direct feed (again) it still didn't run consistantly, so I took it to an auto electrician who said ' its knackered'
Ordered a new bosch one and got to post the old bosch one i have back to the supplier for investigation as to why its failed after 1300 miles, at least this is in warranty unlike my Plasma that blew up this week (3 weeks out of warrenty) and parts aren't available from Hitatchi… what a week
<html>
