Refitting fuel pump.
(In Topic #86766)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/airplane.png)
![dibbler in the usergroup ‘Old timer’ dibbler in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
fuel related, and the fuel line at the "wires end" of the fuel pump
is Pi**ing out, :roll: , the bit that slides over the end of the fuel pump.
When I took the old one off, there was only 2 copper washers that
sat either side of the pipe (it didnt leak then)
Has anyone used some sort of liquid gasket, or should I
have replaced the copper washers?, or used something else.
Thanks in advance
Marc :wink:
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Golf%20Ava5.jpg)
![markwon in the usergroup ‘Local hero’ markwon in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
1983 1100 C
1983 1100 C
![james75 in the usergroup ‘Local’ james75 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
James
1987 Golf Mk1 GTI 1.8 Cabrio
1983 1100 C
1983 1100 C
place I suppose :roll: , Just in a rush to get it all back together!.
I suppose It wont hurt to put a bit of sealer on it as long
as its petrol proof.
Dibbler :wink:
![alplatt in the usergroup ‘Regular’ alplatt in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I changed mine at the weekend but discovered this morning that i'm leaking fuel all over work car park!
Thanks in advance
'81 1.6 GTI & '91 16V
Think mine were 12mm? or 1/2", I didnt use copper ones as
I got some off an engineer at work, they were brass with a
rubber insert (there is a technical name for them but not sure what!)
They worked a treat, and are used in hydraulic things).
Sorry, cant be more help, (off work today) and the car in being
prepped for an MOT, so cant check size.
Good luck anyway :wink:
Dibbler
