What MK1
(In Topic #86601)
What MK1
82 Gti 1.6, Has Sunroof, needs new drivers side inner wing, and work on the rear arches.
83 Gti 1.8, Needs new rear panel, dent in sill, and an aftermarket sunroof.
Advice please :y:
1983 Mk1 Gti 1800
1983 MK1 PIRELLI EDITION
Alpine White LHD ("SOLD")
Pete :wink:
Re: What MK1
:y:
I don't think any car needs an after market sunroof, let alone a classic golf!!
'93 Clipper 1800i
Pearl Green
RH Cups
-40mm
K&N Panel Filter
SADLY NOW WRITTEN OFF
Porsche 944 2.5l LUX Fuchs alloys, pipercross induction - hole in the fuel tank, hopefully!
Pearl Green
RH Cups
-40mm
K&N Panel Filter
he has 10 mk1 gti's and a caddy sport 8) :mrgreen:
1983 Mk1 Gti 1800
Secretary
Best thing for an after market sunroof is a big sheet of metal and a welder
Member 125 - 2005
So i'm getting the 1.8 :mrgreen:
1983 Mk1 Gti 1800
foxymk1 said
can you not chop the roof off the 16 to repair the 18?
Yes ill be cutting the sheet of metal behind the 16's sunroof :y:
1983 Mk1 Gti 1800
wen you weld a piece in it warps as it is only thin
It's going to need a respray anyway
1983 Mk1 Gti 1800
dunk2 said
i was thinking of spot welding it in on the inside, then fill the gap on the roof, :dontknow:
The ONLY way to do it properly is to drill out all the spot welds on replacment roof and then do the same with yours, then spend the time carefully replacing one for the other, any other way it will look like the sea, it will be so rippled
Secretary
OR is this a silly question ops:
