Cutting out - exhaust snapped?
(In Topic #86554)
![Man-Alive in the usergroup ‘Local’ Man-Alive in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
On a short journey it cut out about five times (leaving me in some real hairy side of the road situations - girlfriend has said she will not go anywhere in car again!) - I put these down to re-occurrence of fuel contamination problems and changed over the in-line filter at the side of the road. The cutting out problems continued & I ended up limping along in 3rd gear, cutting out every mile or so. On the way home to add insult to injury the back box snapped. The whole set up of the car then went to pot & would only run for a matter of meters before it cut out again.
My question is could the demise of my exhaust have caused the cutting out problems?
Booked in for a replacement back-box tomorrow afternoon - but I have grave concerns about how it is going to run even after that is sorted.
Thanks Rob.
Black Cabbie
No it's an 8 valve 1.8 with standard carb.
Up until Saturday it has been running pretty good - only ever struggled & cut out when going up big hills.
Black Cabbie
1983 1100 C
1983 1100 C
I thought that regularly replacing the in-line fuel filters would be a short-term fix for this problem?
BTW - taking car to have new back-box fitted this afternoon. Set off to work really early as I expected the same reoccurring cutting out problems. The car ran fine except for the noise from the lack of exhaust!
:dontknow:
Planning to inspect the petrol tank at weekend with a telescopic magnet to see if there is any loose rust in there, also will strip carb down & give it a good clean.
I will post again with info on what I find - cheers Rob.
Black Cabbie
crazyquiff said
It seems that small flakes of rust can get on the end of the pckup causing it to block
Rich -
If it is blocking the pick-up that will explain why changing the in-line filter seemed to make no difference. Do you think the rust is from the old filler neck or from the tank itself?
Also how big a job is removing the tank completly to give it a proper clean?
Black Cabbie
