reverse light hell
(In Topic #86244)
![supermini in the usergroup ‘Regular’ supermini in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
reverse light hell
![bytor in the usergroup ‘Local’ bytor in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
OK, assuming you have one (eco meter), locate the gearbox. On top of that is a 'plug' from which there are wires running to (1) the reversing lights (2) the eco meter. If neither your lights or your eco meter work, then you have an issue with the plug. A new plug can be bought from German, Swedisd and French for about ?14.
Some people have found that the plug from GSF is wired slightly differently to the socket on the gearbox - there are links on here that explain what to do - bit fiddly, but hopefully you'll be lucky like me and it will be a straight swap.
Good luck
:wink:
