Engine?
(In Topic #85129)
Engine?
EXAMPLE
golf - 1.1 - petrol
first golf mk1 im 20yrs old the car is older than me,
golf c 1.1 x plate
golf c 1.1 x plate
Are you saying you are prepared to move/fabricate mounts if necessary, or that you don't want to move mounts?
If you don't want to move mounts, you are limited to 1.1 & 1.3 petrol engines from the early VW range.
If you are prepared to move/fabricate mounts, the world is your oyster! How about a 5.0L V8???!!!
My Build Thread
Mk3 Polo 1.3 GT (3F) is a dead simple swap.
If you don't mind from fabrication (move one engine mount) you can fit 1.8 8v GTI and with a different exhaust manifold, 1.8 GTI. Mk3 Golf engine does fit (but is taller) on GTI mounts so 2.0 16v is a possibility.
1.8 G60 supercharged and 1.8 20valve Turbo will go in but there are more modifications to do.
VR6 is NOT a simple swap but has been done. All depends on your budget.
If you've got now much ???'s then Mk3 Polo 1.3 GT is your best bet.
golf c 1.1 x plate
golf c 1.1 x plate
Steve_Matthews said
Polo 6n2 1.6 16v will bolt pretty much straight in.
I've been thinking of putting a 1.6 16v Polo engine in but i'm not up on the Polo's that much so hopefully u can shed some light. What year is the 6n2 out of? Do u know what exact mods need doing for this to go in as i have the same car as lpkpjh… is it just one mount needs moving or do i have to relocate anything like the servo etc? All help is much appreciated from the experts!!
My friend is trying to by a Seat Arosa off a guy on evil bay and it's had the Polo 1.4 16v engine out of a 98-02 Polo if i remember rightly, then the guy had a turbo put on it by TSR apparently lol i bet that flies….. Would the standard version of that engine fit easily that u know of?
Oh and one final thing…. i've always been curious about the mk4 Tdi or even the GT TDi engines fitting in a mk1… Would that be lots of work do you think? I'm not planning on doing it as i'm not experienced enough but just curious as i said
Karl
'82 Golf C 1.1
also My names Karl too.
golf c 1.1 x plate
golf c 1.1 x plate
tank, suspen, stopin gear, drive shafts, steering arm,
golf c 1.1 x plate
golf c 1.1 x plate
lpkpjh said
if i was to get a 1.8 8v mk2 golf and corrado as a dona car wat would i need,
a divorce
None of those parts apart from possibly the brakes, would be any use.
Tank = Mk1 Golf GTI
Suspension = Mk1 Golf GTI or aftermarket sports suspension, or coilovers
Drive shafts = any big block Mk1
Steering arm = any 5 speed big block Mk1
