rear disks locking up!!!!! HELP!!!!
(In Topic #85150)
![jamiegolf in the usergroup ‘Old timer’ jamiegolf in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
you need to alter the brake bias. i don't know how to do it but i do know it is a shit if a job. trial and error job i think. i'll never ever attempt to even think about rear discs.
![firestormer in the usergroup ‘Local’ firestormer in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![stew72 in the usergroup ‘Local’ stew72 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
jamiegolf said
ok but have you got any idea why i have got a pair of limiter valves under the bonnet and a load valve under the floor at the back?
What years the cabby? If its post 84 I don't think it'll have the valve on the beam as there's not room due to the larger fuel tank.
If you need appropriate inline valves then you'll need 16v scirocco ones, none of the 8v ones are suitable, whatever age of the car.
Alternatively you need to find 2 mk2 astra 16v's and rob the valve with the M10 thread off the master cylinder on each. They have 2 valves, but one is M10 and the other is M12, hence needing to find 2 donors!
![](https://i69.photobucket.com/albums/i77/dstew72/stewvl2.png)
![Richie_T in the usergroup ‘Regular’ Richie_T in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Scrap all the vw stuff (I know its all good but setting it up is a sod) and fit an adjustable bias valve with a lil bit of gental playing in wet car park you'll be sorted
jamiegolf said
my cabby is a 1980 model, and it has got the rear beam valve and its got a smaller fuel tank than my other gti thats on a 1985 plate. mine must just be odd!!!!!! is there any particular astra that i need to get the valves from? or is it any one with the rear disks? i did think about putting an adjustable bias valve in but i was wondering how you would plumb it in cus theres 2 brake pipes going to the rear of the car? do i need 2 adjustable bias valves?
You shouldn't have, and don't need the in-line valves. You'll need the load compensator off an 8v mk2 GTI, that should do the trick. I think it is possible to adjust these, not recommended but possible.
Fitting an inline bias is feasable but you'll loose the dual split circuit and need to re-plumb the front to rear lines, a lot more effort than actually fitting the correct items for the set up you've got.
![woZa in the usergroup ‘Old timer’ woZa in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
jamiegolf said
i have been looking for a set of 256 or 280mm disks and calipers but there so damn expensive these days!!!!!
Look for a set of vauxhall 16v calipers & carriers. Cheap as chips and easy to find. Just need some sleeved bolts. There is a how to somewhere on the forum…
