Battery light stays on
(In Topic #84955)
![Avatar](https://i14.photobucket.com/albums/a334/Pedrosgolf/MK1CitiSteeliesavatar.jpg)
![Peddersgolf in the usergroup ‘Local hero’ Peddersgolf in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
It was fine at 1st, car started thencut out, i tried to restart her but nothing, so i went and bought a new battery.
Starts 1st time but light remains on, i am looking at a possible fault with the alternator? if so what is it that can be causing the problem.
Also my indicators sometimes work then dont, if when i use them as usual the light on the dash stays on instead of flickering, at moment they aint working at all, puzzling me.
Last but not least i have an old fuse box in the 82 gl, with the bullet type fuses, would it be better in the long run to upgrade to a later box plus what does it entail in order to do the swap.
Thanks for taking time in reading the post, hope you can help me
![Avatar](https://img110.imageshack.us/img110/4571/homerrelaxingug7.gif)
![divweir in the usergroup ‘Old timer’ divweir in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
<a><img></a><a href="Login to a private Photobucket.com album
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Golf%20Ava5.jpg)
![markwon in the usergroup ‘Local hero’ markwon in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
1983 1100 C
1983 1100 C
wil get someone to have a look and check it, are the new regulators readily available and what does it look like.
Looked at my citi alternator and the gl one, they are different, why is this
Thanks again
pete :wink:
R.e. the fusebox in your GL, VW changed most of the wriring looms and connectors when they phased out the bullet style box so would be a big job to swap over and not really worth it.
1983 1100 C
1983 1100 C
i posted in wrong section, so heres the link fella, hope you can help.
As regards to indicators i will remove stalks and see if problem is around there.
Anyway heres link to other post
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=19904
Pete
