Fog light problem
(In Topic #84022)
![Avatar](https://img.photobucket.com/albums/v459/lakesk8/DSC00253-1.jpg)
![lakesk8 in the usergroup ‘Old timer’ lakesk8 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Fog light problem
My near side is working fine, the offside is out.
changed the lamps, no good.
pull off both looms and checked for corrosion seems fine.
the offside loom has one less terminal than the right :dontknow:
is this the norm? if not I cant see how it would have just disappeared. :dontknow:
please help
John
2003 MKIV Golf PD150 GT TDI
Just a thought.
If nobody else comes to the rescue, I'll have a look through my manual and see if I can come up with an answer.
Tian :wink:
lakesk8 said
sorry mate i was i bit sparse on the explanation, I don't have front fogs only rearsops:
Ahh, I'll start again then. I'll stand corrected but I was under the impression that you only needed one rear fog light. I was also under the impression that it was standard practice to fit only ONE fog light at the rear. This reduced the chances of it being confused with brake lights. Check out a modern car and see if I'm wrong!
As for fixing the issue, have you looked for broken wires? Have you tried the bulb you know to be good in the broken fitting? Are all other lights in that cluster working okay? Look for a broken earth connection and if none of that helps I'll look at my pdf manual.
Tian :wink:
Web Team
Tian said
I was under the impression that you only needed one rear fog light. I was also under the .
Tian :wink:
I think you are right, but if there is just one, it should be on the offside or centre, not just the nearside.
AFAIK, from when I last changed a mk1 loom (long time ago) the off side foglight is just an extenstion in the wires from the nearside, in theory with the fault being on the offside, tracing a fault should be easier. As Tian says it must be in the wires/connections/bulb/bulb holder somewhere across the back of the car between the two bulbs. You could always try continuity testing for breaks somewhere along the line.
Mine failed a MOT 2 years a go with both rear fogs being too dim. After some consultation on here it was decided it should only have one, so I removed the nearside one and the remaining one shone much brighter.
The previous garage I'd used never noticed.
Try just getting the offside one to work.
you know what it was
the really embarrassing bit
the other one wire loom other than the main loom was unplugged :mrgreen:
John
Web Team
![Avatar](https://img110.imageshack.us/img110/4571/homerrelaxingug7.gif)
![divweir in the usergroup ‘Old timer’ divweir in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
<a><img></a><a href="Login to a private Photobucket.com album
