16v engine in a MK1 by paul-c
![ManicGTI in the usergroup ‘Old timer’ ManicGTI in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![rupe in the usergroup ‘Regular’ rupe in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
ManicGTI said
good plan, I'll update the FAQ and make it a bit more clear :y:
I bought the LUK 8V and 16V clutch kits from GS&F, used the 8V friction plate and 16V pressure plate, and took '16V' clutch back, ahem. They look the same anyway![]()
wonder where you got that idea from dave :wink:
Citi 2L16v
![Avatar](https://i78.photobucket.com/albums/j95/citigolf_2006/Avatar0.gif)
![Bert in the usergroup ‘Local hero’ Bert in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Bert in the usergroup ‘Paid Member’ Bert in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
I need to upgrade the clutch in my TD when it does wear out,i heard about using the 16V pressure plate and the 210mm diesel turbo friction plate with existing flywheel??
What size is the petrol friction plates on 8v and 16v?
TD is 210mm
citigolf is 190mm
Bert
And paul,glad to see a dayco belt going on :wink:
I would send the head set back and go for a Payen set though.
Bert
Bert said
my jetta TD has the free wheeling pulley on the water pump,its weird,never seen one before,the car has power steering.
TD is 210mm
citigolf is 190mm
Bert
Bert
Both 8V and 16V normally use 210mm clutch, there are some early 8Vs and early Digifants which have a 200mm clutch though.
The gasket set was simply what my FLAPS has supplied, hmmmm you have me troubled now…..
Only do it once.
Is the tensioner INA in the box? i see its ruville
Eyes up my a…
Bert
Bert said
New oil cooler too posh git,how much was it?
Bert
?32.50 plus the dreaded, from GSF. They said they did Berg or VW oil coolers, so its OEM quality.
rupe said
Just read the whole thread, looks like its coming on well 8)
He told me to do it guvna! :dontknow:
![](https://vwgolfmk1.org.uk/uploads/pbextract/696265/Dsc03043reduced.jpg)
I dug up the pics of the engine as first arrived, to show the double pulley configuation:
![](https://vwgolfmk1.org.uk/uploads/pbextract/696410/Dsc02828reduced.jpg)
Note the double pulley both on the crank and water pump. The water pump's inner pulley freewheels, its the outer pulley which drives the water pump. Since you don't need to run power steering on a Mk1, you can remove the outer pulley from the crank, replace the 2 pulleys on the water pump with the single pulley (VW part number 027 121 031) and remove the power steering pump and its brackets.
![](https://vwgolfmk1.org.uk/uploads/pbextract/697190/Dsc03048reduced.jpg)
I wanted to see how the induction system and airbox are going to fit. I was planning to cut off the brackets that secure the airbox, from the left of the engine bay (near the battery) and weld them into place the other side, but having seen the proximity to the water pump, alternator, etc I'll construct bolt-on ones nearer the time. I cut a slot in the bottom of the airbox and it holds it on the chassis rail quite nicely, I guess this is what everyone else does.
Since I now have everything to complete it, I could have easily stuck it all in and bolted it up and have it running in a couple of days. Instead, I'm laboriously degreasing and repainting every single little bracket, fitting, etc and I'm also going to tidy up and repaint the engine bay. Its going to take ages….
![woZa in the usergroup ‘Old timer’ woZa in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
But it'll be worth it in the end. If you're going to do it, might as well do it properly…
![bish in the usergroup ‘Regular’ bish in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/697402/Dsc03055reduced.jpg)
This just leaves me with the engine bay to sort out. It has spots of rust everywhere and the front panel is a bit grotty, so its all going to be wire brushed and repainted. Its so intricate in there! And I also need to work around the steering, brake linkage, brake pipes and fuel pipes. Today I ground off the old air box mounts and started on the wire brushing. Here is a 'before' pic.
![](https://vwgolfmk1.org.uk/uploads/pbextract/697402/Dsc03061reduced.jpg)
To be honest the whole car was a wreck. I did the rear end last year, so once the front end is done I'll be happy enough, for now.
![Avatar](https://i38.photobucket.com/albums/e109/MARSREDGTI/DSC02081.jpg)
![marsredgti in the usergroup ‘Old timer’ marsredgti in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Good luck paul!
![](https://i38.photobucket.com/albums/e109/MARSREDGTI/marsredgti.jpg)
![Avatar](https://img.photobucket.com/albums/v502/dubboy/76%20GTI/Driveravatar2.jpg)
Life Member
![dubboy in the usergroup ‘Local hero’ dubboy in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![dubboy in the usergroup ‘Moderators’ dubboy in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![dubboy in the usergroup ‘Paid Member’ dubboy in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/698507/Dsc03084reduced.jpg)
The engine bay is being painted in stages, it takes so long to wire brush because its such an awkward thing, that I can only fit small amounts in per day. This is it 4/5 done in grey stonechip, the only remaining area is the upper section of the rear of the bay. After the stonechip is on I'll apply black topcoat:
![](https://vwgolfmk1.org.uk/uploads/pbextract/698507/Dsc03087reduced.jpg)
![mcscrew in the usergroup ‘Local hero’ mcscrew in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Looking forward to seeing the engine go in!
Rich
