smoke from dashboard>won't start
(In Topic #83911)
![johnnymk1 in the usergroup ‘Regular’ johnnymk1 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I attached a battery starter pack because i knew the battery was bound to be low on charhe and cranked the engine. The starter was going ok and it waas about to start up then stopped so i went to try again and the starter would not spin but the lights were on on the dash. Then i looked over to see smoke wafting from around the fusebox area!!!?
I just had a quick look and all the fuses appear to be fine, any idead as to what it was/is? thankyou, Im going to pop out and keep investigating now :cry:
bloody old cars aaargh!
![Overboost in the usergroup ‘Local’ Overboost in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I went through two of these on my old audi and one on the golf.
Ive replaced the original box with a mk2 fusebox cos i was so fed up of the constant monkeying required.
Best to have the box out and check theres nothing about to set fire behind there.
![dannyboyblue in the usergroup ‘Old timer’ dannyboyblue in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I kept having probs with smoke coming from the dashboard and it turn out one of the fuses kept blowing. Got a new box from GSF and got an auto electrician to fit it in 15mins for not alot of money. That was a couple of years back but if it happened again I'd have a go myself.
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
