Problem when tank less than 1/4 full
(In Topic #81733)
![Avatar](https://i3.photobucket.com/albums/y59/Treadstone81/RachGTIavatar.jpg)
![Rach_GTI in the usergroup ‘Local’ Rach_GTI in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I have a problem when my fuel tank is less than a quarter full (usually around the 280 mile mark!)
If I try to boot it off a roundabout / accelerate out of corner I suddenly get a judder and there's nothing there powerwise until I change up or down a gear….
It is usually when I'm in 3rd gear and have been turning right (duh - that's the way you go round roundabouts right
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
Has anyone else had this? :dontknow:
My dad reckons it could be due to one of the fuel pumps that keeps a resevoir of fuel for just such occasions…
Any thoughts appreciated!
Rach
![MalC in the usergroup ‘Old timer’ MalC in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.golfmk1.co.uk%2Fimages%2FExLink%2FAvatar.jpg)
![crazyquiff in the usergroup ‘Paid Member’ crazyquiff in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![crazyquiff in the usergroup ‘Paid Advertisers’ crazyquiff in the usergroup ‘Paid Advertisers’](https://vwgolfmk1.org.uk/themes/default/images_custom/PaidAdvertiserIcon.png)
![crazyquiff in the usergroup ‘Local hero’ crazyquiff in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
As the fuel drops in the tank the amount of lift the pump has to do is greater. A weak pump will then struggle.
Budget ?35 for the pump - make sure the new one comes with a strainer.
Lift pump is accessed under the rear seat by taking out the level sender.
Rich
Can you buy New ones?
Rach
![danhar707 in the usergroup ‘Regular’ danhar707 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
danhar707 said
I had a similar problem that was fixed by fitting a new bosch pump (the one outside the tank.) It got knackered after running low on fuel. Could tell it was knackered by the amount of buzzing noise it was making. I assume yours has a GTi engine (k-jetronic fuel system.)? Otherwise this will be meaningless to you!
A damaged lift pump sounds a lot like a noisy main pump. And a new main pump is likely to be able to draw fuel better - my money is still on the lift pump
![Avatar](https://i34.photobucket.com/albums/d109/cabriaulait/tijn.jpg)
![cabriaulait in the usergroup ‘Local hero’ cabriaulait in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
youll hear the outside fuel pump from outside the car better.
if your main (outside) pump was knackered youd hear it for sure!
and youd have problems tank full or empty.
rebuild in progress....
![Avatar](https://i9.photobucket.com/albums/a55/laughingboy_1978/a3e1cf5a-b37d-466e-b185-aad4fb4a558e.jpg)
![Laughingboy in the usergroup ‘Local’ Laughingboy in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
IT WORKS!!
![MKI4EVA in the usergroup ‘Regular’ MKI4EVA in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
cabriaulait said
IT WORKS!!
What did you do though, it'll help ppl who search later on.
MKI ABF - Under construction.
and the magnet is still on,,,,,,
There is a loud buzzing to be heard outside the car door (rear driver's side - the pump is accessed on this side of the car under the rear bench I think?) so think its def the lift pump….
New one on 'THE LIST' which grows longer faster than I cross things off
Rach
![bengus23 in the usergroup ‘Newbie’ bengus23 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
