Best gearbox for a 9A conversion?
(In Topic #81307)
______________________________________________
I'm running the std mk1 1.8 GTI box, but i wont pretend its the 'best' for the conversion. Mine runs out of gears around an indicated 120 on my 'private test track'…
The mk2 16v box is apparently virtually the same, but with a 'better' top gear, so planning on changing to that at some point, In no rush though.
The track and 1/4 mile lads on CGTI seem to use the 1.6GTi box because of its low ratios etc, but a bit limiting for lengthy driving (ie motorways)
Ideally you want the mk2 16V (Or late mk1 cabbie) 100mm inner CV joints (larger than 90m mk1 GTI spec). The mk1 boxes will have 90mm flanges so swap some 16v 100mm ones on.
Cable change boxes….not a clue i'm afraid! But I dont know anyone that has bothered if thats an indication. worth it if going 20VT or something I guess!
