A dead MFA
(In Topic #81136)
A dead MFA
Is it just a case of replacing the binicle or is there something else I can check on the car?
Any help would be just grand, thanks
The connections in the back of the dash are probably OK, but connections in the engine bay to all the various sensors/earths will most likely have corroded. Cleaning these may bring the MFA you have back to life. If not it's still worth doing to make sure any replacement MFA works OK.
Ali Cabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
Member 125 - 2005
Sadly, I parked her up last winter as I had no garage for her in the alps, and while she was covered, it looks like a field mouse got in and filled the dash with lots of seeds. The mouse, which also made a lovely nest in my boot out of my favourite picnic rug from Mexico and some paper towel, has possibly chewed through the same cable, and now my MFA does not work anymore. Nor does the drivers' side heated seat. Pah!
Anyway, I recommend you take yours to a good autoelectrician first and see if they can help.
ps - my car looks just like yours.
<img src="http://i35.photobucket.com/albums/d186/Missmoopants/Golfskissing2.jpg" border="0" alt="Two lovely Golfs">
They also once had a feature in Rabbit about their service.
They say disconnecting and reconnecting the battery can damage the MFA,but sometimes when my Golf has not be used and the battery has gone flat or I have taken it off I have had a blank screen and reconnecting the battery a few times has brought all the functions back.
This same 'hiccup' also often occurs if the battery is flattened or disconnected. Instead of displaying the usual range of trip information, the tiny screen either shows just some horizontal lines at the bottom or it goes completely blank! In the worst case this will mean a replacement unit but there is also a quick fix worth trying (you will need a happy helper for this job):
ALWAYS TAKE CARE WHEN DEALING WITH BATTERIES/ELECTRICS
? Disconnect the battery.
? Hold down the MFA button.
? Reconnect the battery.
? While still holding down the MFA button, turn on the ignition, release the button and turn off the ignition.
? Hold down the MFA button again, turn on the ignition and release the button.
You should now have a correctly working display. It has been known for the display to jump into life halfway through the process. If this happens, you can congratulate yourself and stop right there, for it has been known for the computer to 'hiccup' again if the process is continued after it comes back to life!
