Does the MFA show revs ?
(In Topic #80914)
![jon_Bentley in the usergroup ‘Regular’ jon_Bentley in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Paradroid in the usergroup ‘Regular’ Paradroid in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Hairyarse said
I've never heard that one. Don't think you can as far as I'm aware.
* Calling up MFA Check Mode Test
1. Set memory switch to 1
2. Switch ignition on
3. Press/hold mode select switch
4. Switch ignition off, then back on
5. Release mode select switch
or set switch to 2 in step 1 above to use the measuring mode.
![Avatar](https://i43.photobucket.com/albums/e355/ewgolf/mot-500x400-1.jpg)
Web Team
![ew in the usergroup ‘Local hero’ ew in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
MFA switch on position 1:
1. Engine Map code (or Distance Pulse meter should display 6010)
2. Country code
3. Speedometer
4. Upper rev limitter
5. Lower rev limitter
6. Decelaration fuel pressure
7. Display test
MFA switch on position 2:
1. Test sum of programmed bytes
2. Intake manifold (mbar)
3. Digital rev counter (Engine RPM)
4. Fuel usage (like normal)
5. Signal from speedo sensor
6. Oil temperature (like default)
7. Ambient temperature (like default)
Not 100% sure on all the items as the bits of info I've gleaned over the years seem to indicate some of the options are diferent depending on the vehicle.
Thanks for looking
Jon
