Pass the angle grinder - lots of pics
1983 1100 C
1983 1100 C
(Edit 05/06/06: M12 Nut was too big - M12 bolt would not fit through the spacer or seatbelt back. The original bolt is actually an imperial fitting 7/16 UNF - not metric fine as first thought. So you need an imperial nut or use M10 nut and bolt)
Stress plate (drilled for plug welding) and nut.
I drilled a 12mm hole (bolt in position) and a 6.5 hole for seatbelt.
Plate plug welded into place.
Also welded joiner plate for rear panel to tyre well….
…and welded outer sill repair section into place
Bank hoiliday weekend soon so hoping to refit the fuel gear and rear beam :pray:
1983 1100 C
1983 1100 C
fine work there. when i take my rear arch spats off i hope they are ok, that is a full on resto going on over there!
do you live on heath rd? i saw a white GTi and another mk1 under a cover on heath road on friday, it must be you.
look forward to seeing the car on the road soon keep up the good work
:wink:
Jjl.
2003 MKIV Golf PD150 GT TDI
Secretary
Next problem will be attaching them to the thread when I start it.
Cheers for sorting out my last attempt (unpimp your ride) :y:
No, I live in Wivenhoe my GTI's at my parents over Ipswich way, I've no driveway . Do you mean Old Heath rd? Have to have a look next time I driving that way
Stick some pics up Macca, there's a how to attach photos thread in the Websites Issue part of the forum.
1983 1100 C
1983 1100 C
Homemade fuel pump basket cut to shape, brackets from original welded on and painted (one more coat of Hammerite should do).
Seatbelt refitted.
Tyrewell painted up.
Rear arch and quarter with filler primer for final sanding
Four or so coats of Alpine White.
Hopefully be sorting out brake and fuel lines this weekend.
1983 1100 C
1983 1100 C
Web Team
Secretary
Have now posted my own restoration thread. Have managed to sort out the picture problem. Most of the pics that you have posted are identical to the rust problems that I have.
You must be glad that you can now about see the light at the end of the tunnel.
I was hoping to make a lot of headway into my car whilst I'm on holiday, but I twisted my knee whilst attempting to play tennis with the kids whilst in Norfolk on holiday last week. Knees up like a balloon and doc says to rest it. what a bummer.
Keep up the good work :y:
Did you use a spray gun or cans for the painting? Tis a good finish
Just did it with a can. Top quality aerosol though - Max Meyer cellulose paint mixed by local paint factor, very good match and finish. Costs about ?10 a can, but so much better than any of that Hellfrauds/Holt etc rubbish. Will be giving it a proper re-spary in the future, but bodywork needs more work first.
1983 1100 C
1983 1100 C
O/S inner/outer sill repairs complete
View of inner sill repair, quite pleased managed to keep inner sill mouldings
Set about trying to save petrol tank heatshield, lots of surface rust, but all solid. Bottom pic shows underseal cleaned off to reveal clean anodised metal - were they like this from the factory? Going to rust treat and paint high temp paint.
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
i soaked a few gear shift components which had patchy yellow plate like your sheild and it even took it off!
1983 1100 C
1983 1100 C
Secretary
markwon said
Macca - where's the thread, can't see it in the restoration section :dontknow: . It's amazing how mk1's rot in such a similar way, have you seen paul c's thread? Hope the knee gets better soon, your mk1 needs you .
My thread is titled My 1982 1800 GTI, it is on about page 3.
Knees getting there, so much so that I am going to get back out to the Golf after lunch, make the most of the good weather. :wink:
Took a couple of hours to get running, wouldn't fire at first ended up resetting the air mass plate which seemed to be a bit out of adjustment and it fired back into to life. Only problem is fuel weeping from the non-return valve on the fuel pump (bottom photo). I have replaced the copper washers and it has a new pump to accumulator fuel hose so can only assume problem with valve :dontknow: have ordered a new one
Refurbed goodies ready to refit…
Homemade fuel basket finished.
Upward view on new o/s inner acrh with breather gear and filler neck in place. Used stainless steel fittings to help prevent future rust.
Refurbed rear beam.
Rear beam fitted
Fuel leaking!
1983 1100 C
1983 1100 C
IIRC I had the same small leak, sanded the face of the big nut down a little which seemed to cure it :dontknow: might be worth a try
from the pic it doesn't look like the valve leaking
How's your 1600 GTI going?
1983 1100 C
1983 1100 C
