Driver to GTI Conversion
(In Topic #78053)
I am currently converting my 1983 1.3 driver to 1981 1.6 GTI Spec (Donor Car)
I'm at the stage of swapping the looms.
I have removed the 2 looms that go to the engine compartment on the Driver.
The wiring on the GTI donor car is mostly complete, but has been 'modified' in some places.
Can I plug the 2 engine bay looms from the GTI into the driver fuse box? (plus the rear loom for the fuel pump)
OR
Do I have to use the GTI fuse box and plug the existing Driver dashboard looms into it?
(I'm not too bothered about the MFA)
Any help would be appreciated.
Regards Volkswarren
1991 MK2 Golf G60 20VT
1991 MK2 Golf GTI 16V Oak Green
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
Top Reply,NOT!kriss said
Why?! Just buy a GTI and save the hassle
Try and read the topic before replying next time
As for your car mike ,i will get up and have a look at it 8O
see if we can't sort somthing
Cheers Eddie, I will take the old loom out at the wekend and see if I can get my head around it!
Talk to you soon
Carbs4ever said
i hate wires. :cry:
me too! :evil:
quiet a bit of chopping and changing IIRC to go from early style fusebox to late and vice versa
good luck with it
I've changed a 1.6 carb engine to a 2lt injection using the carb loom added digi injection and ecu ect to the 1.6 loom
er no they don't just have extra stuff pluged in. there are two different fuse boxes on a mk1, the 1.6 gti has the early one the 1983 driver has the later one, looms cannot change between the different fuseboxes as they use completely different connetor blocks.crazycar said
you dont need to chane the compleat loom just plug in stuff like hall sender and injection relay/ controls and wiring. basically all the later looms are the same and you'll notice lots of unused plug connectors, the gti's just have extra stuff pluged in.
i take it crazycar was working on a cabrio 1.6? this would have the later fuse box and a digifant loom would plug in.
Regards Volkswarren
My Build Thread
